[postgis-users] Making one out of several connected polygons?
Nicolas Ribot
nicky666 at gmail.com
Fri Feb 1 03:28:37 PST 2008
Try to geomunion() your polygons.
It will create a multipolygon where touching polygons will be unioned.
then, use dump() on the geomunion to extract each polygon.
Example:
the polygon table contains:
test=# select id, astext(geometry) from tpoly2;
id | astext
1 | POLYGON((166 272,107 210,145 142,218 158,209 215,182 240,166 272))
2 | POLYGON((242 118,218 158,145 142,167 104,242 118))
3 | POLYGON((76 161,145 142,167 104,112 78,76 161))
| POLYGON((284 174,283 112,320 124,295 129,302 156,284 174))
(4 rows)
The query to extract unioned polygon based on a common edge:
select astext(geom(dump(geom))), path(dump(geom))
from (select geomunion(t1.geometry)::geometry as geom
from tpoly2 t1
) as foo;
Leads to this result:
astext
| path
POLYGON((284 174,302 156,295 129,320 124,283 112,284 174))
| {1}
POLYGON((76 161,145 142,107 210,166 272,182 240,209 215,218 158,242
118,167 104,112 78,76 161)) | {2}
(2 rows)
(see polygon.png and result.png images done with openjump)
HTH
Nicolas
On 01/02/2008, Simon Schneider <Kallas at gmx.de> wrote:
> Hi,
> I've several polygons wich are all connected by at least one line and
> I'm looking for a way to make one big polygon which contains all the
> others. In other words the shape of the polygoncluster.
> I've been locking around for quite a while but I found no way to solve
> this within postgis.
> Cheers,
> Simon
> postgis-users mailing list
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080201/5bb2a8a0/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080201/5bb2a8a0/attachment-0001.png>
