[postgis-users] Automated area calculating
Johannes Sommer
johann.online at gmx.de
Sun Feb 3 02:19:35 PST 2008
Hi Michael,
Michael Fuhr schrieb:
> What's the CREATE TRIGGER statement?
> CREATE OR REPLACE FUNCTION calc_area()RETURNS trigger AS
> $BODY$
> BEGIN
> NEW.area := st_area(NEW.geometry);
> RETURN NEW;
> END;
> $BODY$
> LANGUAGE plpgsql;
I tried this before - but no calculation happened. The important hint
was the Trigger statement.
I did a "AFTER INSERT OR UPDATE" because I didn't know better. With
CREATE TRIGGER test_calc_area
BEFORE INSERT OR UPDATE ON test FOR EACH ROW
EXECUTE PROCEDURE calc_area();
everything worked fine. Thank you for your help, Michael.
But I still don't know why you have to fire the trigger BEFORE an INSERT
OR UPDATE and not AFTER this
happens.
greetings,
Johannes
Solution to automated area calculation:
--Start
CREATE OR REPLACE FUNCTION calc_area() RETURNS "trigger" AS
$BODY$
BEGIN
-- Important: declare as 'CREATE TRIGGER BEFORE INSERT OR UPDATE' and not
-- 'AFTER INSERT OR UPDATE'
NEW.area_qm:=st_area(NEW.geometry);
NEW.area_ha:=NEW.area_qm/10000.;
RETURN NEW;
END;
$BODY$
LANGUAGE 'plpgsql' VOLATILE;
ALTER FUNCTION calc_area() OWNER TO postgres;
--End
