[postgis-users] pg_restore fails for postgis data dump
Stefan Schwarzer
stefan.schwarzer at grid.unep.ch
Wed Feb 6 01:01:40 PST 2008
> Hi there,
> I just wanted to restore a dump which I did, which includes some
> postgis data. But, it doesn't work and instead I get this error
> message:
> pg_restore: restoring data for table "boundaries_national"
> pg_restore: [archiver (db)] error returned by PQputCopyData: server
> closed the connection unexpectedly
> This probably means the server terminated abnormally
> before or while processing the request.
> pg_restore: *** aborted because of error
> The log shows this:
[snip ]
> What does it mean? The dump is from a 8.1 database, whereas the new
> one is 8.2. There is surely as well some difference in postgis
> version. Can it be linked to that? I am working with Leopard.
I have the impression that there are two methods for re-inserting a
(postgres/postgis) dump:
1) pg_restore
2) postgis_restore.pl lwpostgis.sql newdb olddb.dump -E=UNICODE >
restore.log
If my postgis functions are already installed in the database, then I
would go for the first solution, no?
But how to handle different versions of Postgis? Does it play a role?
How do I upgrade?
Thanks for any advice.
Stef
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080206/dfcc00f7/attachment.bin>
