[postgis-users] SRID 32767 or 4326
Guido Lemoine guido.lemoine at jrc.it
Wed Feb 6 06:33:06 PST 2008
Dear All,
My colleague installed postgis 1.3 recently. He then inserted some KML
polygon
data using (GDAL) ogr2ogr. This gets loaded in a table which has it's SRID
set to 32767.
In the 1.3 version of the spatial_ref_sys table, SRID=32767 is defined as a
longlat projection.
In MY 1.2 version of spatial_ref_sys, SRID=32767 is defined as a UTM
zone 42N projection (WGS84). I use SRID=4326 for longlat projection,
which has worked fine until now (I export features as KML for Google Earth).
Is this something I have to worry about (esp. when upgrading)?
GL
Guido Lemoine
Joint Research Centre, European Commission
Institute for the Protection and Security of the Citizen (IPSC)
Support to External Security
Via E. Fermi, 2749 TP 267 Ispra 21027 (VA), Italy
Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
WWW: http://ses.jrc.it
Disclaimer:
Views expressed are those of the individual and do not represent
the views of the European Commission
