[postgis-users] Convert x, y into geometry and update two geometries
Kevin Neufeld kneufeld at refractions.net
Wed Feb 6 08:55:42 PST 2008
Really? Your trigger seems to work for me.
CREATE SCHEMA test;
CREATE TABLE test.nodes (point_x int, point_y int, the_geom geometry);
CREATE OR REPLACE FUNCTION test.calc_point()
  RETURNS "trigger" AS
  $BODY$
  BEGIN
    NEW.the_geom:=SetSRID(MakePoint(new.point_x, new.point_y), -1) ;
  RETURN NEW;
  END
  $BODY$
  LANGUAGE 'plpgsql' VOLATILE;
CREATE TRIGGER insert_nodes_geom
  BEFORE INSERT OR UPDATE
  ON test.nodes
  FOR EACH ROW
  EXECUTE PROCEDURE test.calc_point();
INSERT INTO test.nodes (point_x, point_y) VALUES (1,2);
SELECT point_x,point_y,astext(the_geom) FROM test.nodes ;
 point_x | point_y |   astext
       1 |       2 | POINT(1 2)
(1 row)
Cheers,
Kevin
Broun Uganda wrote:
> When i use the code below, it is executed data is transferred to the
> database but the geom is not inserted.
> CREATE OR REPLACE FUNCTION calc_point()
> $BODY$BEGIN
> RETURN NEW;
>  END$BODY$
>   ON nodes
>   FOR EACH ROW
>   EXECUTE PROCEDURE calc_point();
> Broun Uganda
> Express yourself instantly with MSN Messenger! MSN Messenger
> <http://clk.atdmt.com/AVE/go/onm00200471ave/direct/01/>
> postgis-users mailing list
