[postgis-users] Exporting 3D Shape to PostGIS
Matthew Pulis
mpulis at gmail.com
Fri Feb 8 09:01:50 PST 2008
Hi Kevin and the rest :)
Seems like it did the trick :
select asewkt(the_geom) from streets_3d where gid=1;
"MULTILINESTRING((625304.649659493 214113.544271209 111.1573080888
0,625301.199687227 214078.520974251 111.1573080888 0,625299.489760683
214056.176602372 111.1573080888 0,625299.289850496 214050.649031119
111.1573080888 0))"
As opposed to :
select asewkt(the_geom) from streets where gid=1;
"MULTILINESTRING((625304.649659493 214113.544271209,625301.199687227
214078.520974251,625299.489760683 214056.176602372,625299.289850496
214050.649031119))"
I can take it that 111.1573080888 is the altitude right? (considered as z
coordinate)
Am I right in my supposition?
Thanks a lot for your help :)
Matthew
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Kevin
Neufeld
Sent: Friday, February 08, 2008 5:49 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Exporting 3D Shape to PostGIS
http://postgis.refractions.net/docs/ch06.html#id2615538
ST_AsText(Geometry) returns the WKT representation according to OGC
standards, which does not include 3D values.
Try PostGIS's WKT extension instead: ST_AsEWKT(Geometry)
Cheers,
Kevin
Matthew Pulis wrote:
> Hi,
> I have a 3D Shapefile, which I am trying to export to a PostGIS table.
> This is the an extract from the ogrinfo on the shape file :
> yancho at Ubuntu:~$ ogrinfo -so streets3d_new_shps/ testogr
> Geometry: 3D Line String
> Feature Count: 49746
> Extent: (610869.384850, 196653.348553) - (676816.248304, 258102.572101)
> Layer SRS WKT:
> PROJCS["Lambert Conformal Conic",
> GEOGCS["grs80",
> DATUM["North_American_Datum_1983",
> SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Lambert_Conformal_Conic_2SP"],
> I exported this shapefile to PostGIS table and this is the result of this
> query :
> select astext(the_geom) from streets_3d where gid=1; :
> 214050.649031119))"
> And this is the resulting query from the streets table which is the normal
> 2D table :
> select astext(the_geom) from streets where gid=1; :
> 214050.649031119))"
> Any idea what I can do so I can start using elevation on this table
please?
> Any help will be extremely appreciated
> Regards
> Matthew
> _____
> I am using the free version of SPAMfighter for private users.
> It has removed 22873 spam emails to date.
> Paying users do not have this message in their emails.
> Try SPAMfighter <http://www.spamfighter.com/len> for free now!
> postgis-users mailing list
It has removed 22884 spam emails to date.
Get the free SPAMfighter here: http://www.spamfighter.com/len
