[postgis-users] ST_within bug?
Johannes Sommer
johann.online at gmx.de
Thu Feb 14 01:13:09 PST 2008
Ok, thank you for the clearing answers.
Paul Ramsey schrieb:
> Right, so you're seeing very slight coordinate drift. Probably Kosmo
> is inserting the object as hex-encoded WKB, and then your other
> application is pulling WKT, which is ever-so-slightly different than
> the underlying binary. The only way to avoid drift and precision
> issues is to get both applications using exactly the same
> representation, preferably the more exact WKB ones.
> On Feb 13, 2008, at 12:14 PM, Johannes Sommer wrote:
>> Hi Paul,
>> The update worked. Now I get the correct boolean values. But my
>> problem is not solved.
>> As I wrote the problem is that the Desktop Client tries to insert a
>> geometry object as GeometryFromText in a way that results in a
>> slightly different binary geometry object.
>> example:
>> application (Kosmo) insert:
>> 7;"0103000020EC7A000001000000060000007101EE208F2E51416E <----
>> 252C38668A5441320DDB8DF62F514174604A3E2E8A544154E6C014F52F514164A38519888A54418CAB1FB4132F5141C4<---
>> F318A8BB8A54415<---
>> 36F90B2A62E514125384224A18A54417101EE208F2E51416E252C38668A5441"
>> after update in psql-terminal (ST_GeomFromText...):
>> 7;"0103000020EC7A000001000000060000007001EE208F2E51416D <----
>> 252C38668A5441370DDB8DF62F514176604A3E2E8A54414FE6C014F52F514163A38519888A54418CAB1FB4132F5141C2<---
>> F318A8BB8A54414<---
>> E6F90B2A62E514129384224A18A54417001EE208F2E51416D252C38668A5441"
>> I'm not sure, but I think Kosmo uses "GeometryFromText" (I have asked
>> the list for this).
>> I could not reproduce the reaction in a psql terminal with
>> "GeometryFromText". If I do the INSERTS on the terminal, I get the
>> correct results.
>> Can this happen if one uses (GeometryFromText, SRID) instead of
>> (ST_GeomFromText, SRID) in an application with JDBC-Driver?
>> thanks,
>> Johannes
>>> I think your geometries have slightly different topology than your
>>> text representations admit. I cannot reproduce your result, but then
>>> I started from your text representations.
>>> Do this:
>>> update test set geometry =
>>> ST_GeomFromText('POLYGON((4506577.35665529
>>> 5381992.48407281,4506597.92548351 5381745.65813424,4506999.01763368
>>> 5381784.22468715, 4506834.46700796 5382069.61717861,4506615.92320819
>>> 5382085.04379977,4506577.35665529 5381992.48407281))', 31468) where
>>> t_id = 3;
>>> And then see what happens.
>>> On Feb 13, 2008, at 3:44 AM, Johannes Sommer wrote:
>>>> Hi,
>>>> I ve got a problem with the ST_Within() function. It does not
>>>> always return correct answers.
>>>> SELECT AsText(geometry) FROM test WHERE t_id=3;
>>>> -->result:
>>>> "POLYGON((
>>>> 4506577.35665529 5381992.48407281,
>>>> 4506999.01763368 5381784.22468715,
>>>> 4506615.92320819 5382085.04379977,
>>>> 4506577.35665529 5381992.48407281))"
>>>> -- (WKT/WKB):
>>>> SELECT ST_Within(ST_GeomFromText('POLYGON((
>>>> 4506577.35665529 5381992.48407281))', 31468), a.geometry) FROM test
>>>> a WHERE t_id=3;
>>>> -->result: false (but obviously it should be true)
>>>> -- (WKT/WKT):
>>>> 4506577.35665529 5381992.48407281))', 31468), (SELECT
>>>> AsText(geometry) FROM test WHERE t_id=3));
>>>> --> result:
>>>> ERROR: Operation on two geometries with different SRIDs
>>>> KONTEXT: SQL function "st_within" statement 1
>>>> Ok - I understand this reaction, because AsText returns no SRID.
>>>> -- (WKT/WKT):
>>>> SELECT ST_Within((select st_astext(geometry) FROM test WHERE
>>>> t_id=3), (SELECTst_astext(geometry) FROM test WHERE t_id=3));
>>>> -->result: true (as it should be)
>>>> -- (WKB/WKB):
>>>> select st_within((SELECT geometry FROM test WHERE t_id=3), (SELECT
>>>> geometry FROM test WHERE t_id=3));
>>>> -->result: true (correct)
>>>> So the problem is that the Desktop Client tries to insert a
>>>> geometry object as GeometryFromText / ST_GeomFromText / GeomFromText
>>>> and I have to compare this new geometry object with an existing
>>>> Polygon.
>>>> It makes no difference if I use _st_within / st_within / within,
>>>> geometryfromtext / st_geomfromtext / geomfromtext or astext /
>>>> st_astext.
>>>> I used:
>>>> -Windows XP, "POSTGIS="1.3.1" GEOS="3.0.0rc4-CAPI-1.3.3" PROJ="Rel.
>>>> 4.5.0, 22 Oct 2006" USE_STATS",
>>>> "PostgreSQL 8.2.5 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC)
>>>> 3.4.2 (mingw-special)"
>>>> -Linux, "POSTGIS="1.3.2" GEOS="3.0.0rc5-CAPI-1.4.0" PROJ="Rel.
>>>> 4.6.0, 21 Dec 2007" USE_STATS",
>>>> "PostgreSQL 8.2.6 on i686-pc-linux-gnu, compiled by GCC gcc (GCC)
>>>> 4.2.1 (SUSE Linux)"
>>>> Where am I going wrong?
>>>> regards,
>>>> Johannes
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
