[postgis-users] postgres 8.3
Chetan Tiwari chetan.tiwari at gmail.com
Mon Feb 18 20:36:37 PST 2008
Hi Facundo
I suppose it is a good idea to run the latest version. I personally had some
concerns about migrating a set of pl/pgsql functions that I had previously
written using 8.2, but it all worked out well for me!
- Chetan
On Feb 18, 2008 11:28 AM, Facundo Garat <facundo.garat at novare.com.uy> wrote:
> Thanks Chetan... i will give it a try then.
> Do you recomend me to use 8.3 instead of 8.2?
> facundo.-
> On Feb 18, 2008 1:40 PM, Chetan Tiwari <chetan.tiwari at gmail.com> wrote:
> > Yes it does. To install postgis, you need to use the 'Application Stack
> > Builder' that comes with PostgreSQL 8.3.
> > - Chetan
> > On Feb 18, 2008 8:30 AM, Facundo Garat <facundo.garat at novare.com.uy>
> > wrote:
> > > Hi,
> > >  it's postgres 8.3 supported by the latest version of postgis?.
> > > thanks.
> > > Facundo Garat Mayer
> > > facundo at garat.net
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Facundo Garat Mayer
Chetan Tiwari
Dept. of Geography, The Univ. of Iowa
316 Jessup Hall, Iowa City, IA 52242
Ph. (319) 335-0165 Fax (319) 335-2725
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080218/3acaed06/attachment.html>
