[postgis-users] Projection for Calculating Area
Travis Kirstine
traviskirstine at gmail.com
Thu Feb 21 09:33:17 PST 2008
All,
We have been developing a web mapping application using google maps as
the front end interface with a postgis backend. Using this
application the user can draw a bounding box in google maps and the
coordinates are then passed to postgis. With postgis we then perform
a query on the polygons stored in the postgis database to return the
area using ST_Intersection, ST_Transform (usually to UTM) and finally
ST_Area. The application works great but the problem is that since
we are trying to work on a global scale it is difficult to determine
what projection (EPSG) to transform the data to calculate an accurate
area since our data is in EPSG:4326 and returns decimal degrees. We
can easily transform the query results to a UTM or a Albers projection
however the results can be inaccurate since the user may select
multiple zones or hemispheres when view the map at a global scale. Is
there a accurate global projection for calculating area?
Travis K.
Toronto, Canada
"She knows there's no success like failure
And that failure's no success at all."
-Bob Dylan-
