[postgis-users] Scripts to update spatial_ref_sys.sql?
Robert Coup
robert.coup at onetrackmind.co.nz
Tue Jan 1 17:53:16 PST 2008
On 02/01/2008, Frank Warmerdam <warmerdam at pobox.com> wrote:
> GDAL/OGR includes a script called epsg_tr.py that makes it relatively easy
> to translate from epsg codes to various formats.
Sweet. I'll have a look.
You will likely want to do this for pcs.csv (all the projected coordinate
> systems) and gcs.csv (all the geographic coordinate systems). The .csv
> files
> are part of the GDAL/OGR source distribution and are often installed in
> /usr/local/share/gdal on linux/unix.
And (technically now a gdal question) how do the csv files get produced? ie.
from the EPSG dataset available at epsg.org they get loaded into a postgres
db and another script gets run to produce the csv files?
Thanks,
Rob :)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080102/ad6b182d/attachment.html>
