[postgis-users] function addgeometrycolumn does not exist
Gregory Williamson
Gregory.Williamson at digitalglobe.com
Tue Jan 1 20:48:02 PST 2008
Off hand, I'd guess that you are not giving the right parameters.
> However when I list my functions using \df this is a snippet of what i see:
> public | addgeometrycolumn | text | character varying, character varying,
> character varying, character varying, integer, character varying, integer
4 varchar params, an integer, another varchar and another int
OR
3 varchar params, an int, a var char and another int.
OR
2 varchar params, an int, a var char and an int
You had:
test=# select AddGeometryColumn('public','navaids','geom',32611,2);
so 3 varchars, and 2 ints.
PostgreSQL is complaining correctly that there is no match.
I don't have a manual at hand but it seems to me are missing a parameter ... try rereading the documents and see what the columns are defined as. I think maybe you are missing a specification of what sort of geometry is to be used (POINT, POLYGON, GEOMETRY, etc.). Perhaps the missing text from the second variant, between the two int parameters ?
HTH,
Greg Williamson
Senior DBA
GlobeXplorer LLC, a DigitalGlobe company
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080101/794bf972/attachment.html>
