[postgis-users] PostgreSQL / PostGIS Issue - SQL state: 42883
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Thu Jan 3 23:37:30 PST 2008
On Thu, 2008-01-03 at 18:58 -0500, Darrell Sher wrote:
> You are correct the PostGIS installer did put the liblwgeom.so file
> under /usr/lib64/pgsql. I have made the other changes you recommended
> and the issue remains. (Yes I did restart PostgreSQL J  )
> Darrell
Hi Darrell,
In that case, the only other I can think of is to check your SELinux
settings for all the files. In particular, do non-root users have read
access to /usr/local/lib and its contents? You may need to try
permissive mode in order to see which files cannot be accessed in the
SELinux log.
HTH,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
