[postgis-users] geometry column permission denied using shp2pgsql
David Epstein davideps at umich.edu
Wed Jan 9 01:48:41 PST 2008
    Hello,
        I am the owner of the database but am getting a permission
        denied on the
        geometry column when using shp2pgsql. There seems to be a
        character
        encoding issue also. The data was likely created on a computer
        running
        windows in Hebrew (reads right to left) and I am running ubuntu
        in
        English. Any help would be appreciated. I've pasted the output
        below.
        thank you in advance,
        -david
        --> shp2pgsql -s 2039 -W ISO-8859-8 URBANI.shp urban_areas |
        psql
        spatialtest
        Shapefile type: Polygon
        Postgis type: MULTIPOLYGON[2]
        SET
        BEGIN
        NOTICE:  CREATE TABLE will create implicit sequence
        "urban_areas_gid_seq" for serial column "urban_areas.gid"
        NOTICE:  CREATE TABLE / PRIMARY KEY will create implicit index
        "urban_areas_pkey" for table "urban_areas"
        CREATE TABLE
        ERROR:  permission denied for relation geometry_columns
        CONTEXT:  SQL statement "DELETE FROM geometry_columns WHERE
                        f_table_catalog = '' AND f_table_schema =
        'public' AND
        f_table_name = 'urban_areas' AND f_geometry_column = 'the_geom'"
        PL/pgSQL function "addgeometrycolumn" line 94 at execute
        statement
        SQL statement "SELECT AddGeometryColumn('', $1 , $2 , $3 , $4 ,
        $5 ,
        $6 )"
        PL/pgSQL function "addgeometrycolumn" line 4 at SQL statement
        ERROR:  current transaction is aborted, commands ignored until
        end of
        transaction block
        end of
        transaction block
        WARNING:  nonstandard use of \' in a string literal
        LINE 1: ...VALUES ('8.88287388491e+003','1.23130983450e
        +006','בוענה נז
        HINT:  Use '' to write quotes in strings, or use the escape
        string
        syntax (E'...').
        end of
        transaction block
        end of
        transaction block
        end of
        transaction block
        --> sudo tail -n 50 /var/log/postgresql/postgresql-8.2-main.log
        2008-01-09 10:35:25 IST HINT:  Use the escape string syntax for
        escapes,
        e.g., E'\r\n'.
        2008-01-09 10:35:25 IST WARNING:  nonstandard use of escape in a
        string
        literal at character 84
        escapes,
        e.g., E'\r\n'.
        2008-01-09 10:49:05 IST NOTICE:  CREATE TABLE will create
        implicit
        sequence "urban_areas_gid_seq" for serial column
        "urban_areas.gid"
        2008-01-09 10:49:05 IST NOTICE:  CREATE TABLE / PRIMARY KEY will
        create
        implicit index "urban_areas_pkey" for table "urban_areas"
        2008-01-09 10:49:05 IST ERROR:  permission denied for relation
        geometry_columns
        2008-01-09 10:49:05 IST CONTEXT:  SQL statement "DELETE FROM
        'public' AND f_table_name = 'urban_areas' AND f_geometry_column
        'the_geom'"
        statement
        $3 , $4 ,
        $5 , $6 )"
        statement
        2008-01-09 10:49:05 IST STATEMENT:  SELECT
        AddGeometryColumn('','urban_areas','the_geom','2039','MULTIPOLYGON',2);
        2008-01-09 10:49:05 IST ERROR:  current transaction is aborted,
        commands
        ignored until end of transaction block
        2008-01-09 10:49:05 IST STATEMENT:  INSERT INTO
        "urban_areas" ("shape_leng","shape_area","שם_הישוב","הערות","הסבר",the_geom) VALUES ('9.06802995385e+003','1.01826276165e+006','עילבון','ישוב',NULL,'SRID=2039;01060000000 [text removed here] 1008BE226418C406025410C0D41F2C4D21C8CE22641');
        commands
