[postgis-users] Area calculation oh two polygon that they are overlapping
Guido Lemoine
guido.lemoine at jrc.it
Thu Jan 10 07:42:06 PST 2008
Your multipolygon is simply two rings of 3 by 3. Defining them
as multipolygon does do nothing for intersection, so the area is 18
(which is 9 + 9). You need to look up what intersection means.
For me, the intersection of the 2 polygons is the common area,
which is 4.
GL
olivier.amram at free.fr wrote:
> Hi,
> I'd like to compute the total area of polygon that intersects with another
> polygon
> Polygon(0 0,0 3,3 3,3 0,0 0)
> Polygon(1 1,4 1,4 4,1 4,1 1)
> The total area is 14 but I don't find a solution to compute this value.
> e.g. SELECT Area(GeomFromText('MultiPolygon( ((0 0,0 3,3 3,3 0,0 0)),((1 1,1 4,4
> 4,4 1,1 1)))')) --> 18
> Have you any idea ?
> Thank,
> Olivier.
> postgis-users mailing list
Guido Lemoine
Joint Research Centre, European Commission
Institute for the Protection and Security of the Citizen (IPSC)
Support to External Security
Via E. Fermi, 2749 TP 267 Ispra 21027 (VA), Italy
Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
WWW: http://ses.jrc.it
Disclaimer:
Views expressed are those of the individual and do not represent
the views of the European Commission
