What do you get when you try : SELECT AsText(ST_LineMerge(ST_Collect(the_geom))) FROM admin.plz WHERE gid = 15 OR gid = 16; -- Kevin Andreas Neumann wrote: > ... > Here is my second SQL: > > SELECT gid,AsText(the_geom) FROM admin.plz WHERE gid = 15 OR gid = 16; > > Result: MULTILINESTRING(...) >
