[postgis-users] Pipeline Data Model
Burgholzer,Robert
rwburgholzer at deq.virginia.gov
Mon Jan 14 04:36:55 PST 2008
Abe,
I am downtown on Main St. Small world.
As for a project with routing and so forth, I am all for it. I have already started a project with specific routing routines for surface hydrology. Part of this project contains a library of PostgreSQL functions written in C for doing such things as infiltration and open channel flow routing using SQL functions. It would be interesting to extend this. My work revolves around surface water supply planning, and I could see how a pipeline data model and associated routines would be helpful. My other work is on developing the technical infrastructure for doing a dynamic web-based decision support system that integrates water quantity and quality monitoring, analysis, and modeling. It has a Stella/PowerSim-like way of connecting model components, and a scenario based method of data storage for exploring what-ifs.
The main sourceforge site is:
http://sourceforge.net/projects/npsource/
The PostgreSQL functions are under the package "pgSQL_hydro", and the decision support system is under "Web Hydrology Objects".
I would be willing to add a section/package for the pipeline model under the "npsource" project (and associated administrator/maintainer accounts for those who are interested), or we can set up an entirely new project for this routing model.
I look forward to hearing from interested parties.
r.b.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of Abram Gillespie
Sent: Fri 1/11/2008 5:43 PM
To: PostGIS Users Discussion
Cc:
Subject: Re: [postgis-users] Pipeline Data Model
Robert, this sounds great. I'll give it a try this weekend.
BTW - where are you located? I'm in Richmond myself.
-Abe
On Jan 11, 2008 1:05 PM, Burgholzer,Robert
<rwburgholzer at deq.virginia.gov> wrote:
> Dane,
> This is interesting, but I have never experienced the error that you
> showed the link to. I will speculate that it is limited to certain data
> types.
> To answer Abram's question, yes, you can (in my experience) push them
> directly. The only errors that I have encountered were when my ODBC
> connection had the wrong Postgres version in the connection dialog.
> Otherwise, I have "pushed" probably 100 tables into postgres with no
> trouble.
> I think it is worth a try!
> Robert W. Burgholzer
> Surface Water Modeler
> Office of Water Supply and Planning
> Virginia Department of Environmental Quality
> 804-698-4405
> Open Source Modeling Tools:
> Web-Based Water Supply Planning Demo:
> http://soulswimmer.dynalias.net/models/wsdemo/demo_hsi.php
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Dane
> Springmeyer
> Sent: Thursday, January 10, 2008 6:47 PM
> Robert and Abe,
> On Jan 10, 2008, at 12:48 PM, Burgholzer,Robert wrote:
> > If you have set up an ODBC connection to your PostgreSQL database, the
> > tables can be loaded into postgres from MSAccess by using Access's
> > "Export" function.
> That has also been my method for going from MS Access => Postgres. In
> my case I set up the ODBC connection on a windows machine then dump
> the non-spatial tables from postgis to then restore into postgis on a
> linux or mac os x machine. If you try to export the spatial tables
> you'll get an error like this (which I have never tried to get around):
> http://archives.postgresql.org/pgsql-bugs/2002-12/msg00174.php
> Abe asked:
> > But are you saying you can push the table
> > definitions from Access into Postgres?
> I am only aware of the ability to export the table with definitions
> of field types - nothing more... since the odbc export functionality
> operates on individual tables.
> mdbtools (see below) exports basic schema from mdbs with multiple
> tables but not relationships. DBcovert can export sequences and
> constraints but I am not sure what else.
> > If there are spatial columns in there, this will be
> > a difficulty, but the regular data will upload. Of course, any
> > linkages
> > will have to be reconstituted by hand, but it is a reasonable
> > method in
> > my experience.
> I bring in the spatial columns on their own shp2pgsql.
> Converting both attribute and spatial columns using shp2pgql is not
> ideal because of the hassle of having all column names chopped off at
> 10 characters at the shp/dbf step.
> I've tried ogr2ogr with the PGEO driver but at this point bugs in the
> mbdtools dependency have made that a *real* challenge. It currently
> only feasible on a windows machine:
> http://www.postgis.org/pipermail/postgis-users/2006-October/013651.html
> If anyone makes progress on this front do post more ideas. I can tell
> from list archives that there is good reasons to avoid thinking of
> postgis as a file converter, but this MDB => Postgis issue is bound
> to require more and more attention as people discover postgis.
> Cheers,
> Dane
> > 804-698-4405
> > Open Source Modeling Tools for NPS analysis and Water Supply Planning:
> > George Silva
> > Sent: Thursday, January 10, 2008 3:10 PM
> > Abe, here is the XML file. Its a product of ArcGis Diagrammer.
> > Note: this is APDM version 2. I cant seem to build in version 4. Ill
> > look into it.
> > If you do build that code, i would to see it very much ;)
> > Att.
> > George
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080114/e76c5405/attachment.bin>
