[postgis-users] ERROR: Operation on two geometries with different SRIDs
Kevin Neufeld
kneufeld at refractions.net
Tue Jan 15 09:19:25 PST 2008
What do you get when you issue this query?
SELECT ST_SRID(the_geom), count(*)
FROM "public"."kanagawa"
GROUP BY ST_SRID;
-- Kevin
Andrea Maschio wrote:
> Hello, while trying to dome this query in geoserver, I've got the
> following error: ERROR: Operation on two geometries with different
> SRIDs. My kanagawa table (downloaded from pgrouting sample app, was
> registered in geometry column with SRID 4326(manually by me). I cannot
> understand what's happening, because I simply don't understand wich is
> the second geometry that (probably) has the SRDI=-1. Any clue?
> SELECT "gid", "length", "x1", "y1", "x2", "y2", "source", "target",
> encode(AsBinary(force_2d("the_geom"), 'XDR'),'base64') FROM
> "public"."kanagawa" WHERE "the_geom" && GeometryFromText('POLYGON
> ((138.86892242431625 35.10309162139895, 138.86892242431625
> 35.69988307952885, 139.90027313232477 35.69988307952885,
> 139.90027313232477 35.10309162139895, 138.86892242431625
> 35.10309162139895))', 4326) AND intersects("the_geom",
> GeometryFromText('POLYGON ((138.86892242431625 35.10309162139895,
> 138.86892242431625 35.69988307952885, 139.90027313232477
> 35.69988307952885, 139.90027313232477 35.10309162139895,
> 138.86892242431625 35.10309162139895))', 4326))
> Thanks
> Andrea Maschio
> postgis-users mailing list
