[postgis-users] Importing 3d Shape File
Matthew Pulis mpulis at gmail.com
Wed Jan 16 03:01:43 PST 2008
I created a shape file using GRASS which has 3D Geometry. Basically I used
the GRASS command (v.drape) to connect a raster layer with elevation and a
streets 2D layer.
The shape file is a 3D file and can be confirmed here :
http://solutions-lab.net/thesis/vinfo.txt
(Map is 3D:              1    )
And here : http://solutions-lab.net/thesis/test2.txt
(Geometry: 3D Line String)
Now my main problem is how I am going to convert this shape file into a
PostGIS table. Which tools would I need? Should I continue asking in the
GRASS mailing list or there are some tools of PostGIS (such as the shp2sql)
which still work for me in this case?
Thanks for your guidance
Matthew
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080116/5f4a2be6/attachment.html>
