[geos-devel] Re: [postgis-users] ST_Contains doesn't work?
KXK
vivahome2 at gmail.com
Thu Jan 17 20:35:21 PST 2008
Paul
Thanx for a quick reply.
At http://trac.osgeo.org/geos, I issued a ticket whose number is #171.
KXK
2008/1/18, Paul Ramsey <pramsey at refractions.net>:
> I think this must be arising in the "I'm a box so I can short-circuit
> full computation" code. The error displays with different combinations
> of square and non-square arguments.
> On Jan 17, 2008, at 7:55 PM, Paul Ramsey wrote:
> > I just confirmed this behavior. true/true on geos 2.2 true/false on
> > geos 3.0.
> > Please file this at http://trac.osgeo.org/geos, it's real, and it's
> > not right.
> > P
> > On Jan 17, 2008, at 7:35 PM, KXK wrote:
> >> SELECT
> >> ST_Contains(
> >> GeomFromText('POLYGON((0 0,0 10,10 10,10 0,0 0))', -1),
> >> GeomFromText('POLYGON((5 5,5 6,6 6,6 5,5 5))', -1) );
> >> returns TRUE
> >> But,
> >> SELECT
> >> ST_Contains(
> >> GeomFromText('POLYGON((0 0,0 11,11 10,10 0,0 0))', -1),
> >> returns FALSE
> >> I thought the above would also return TRUE.
> >> Is this behavior of ST_Contains correct?
> >> [VERSION INFORMATION]
> >> OS: fc6
> >> PostgreSQL: 8.2.4
> >> PostGIS: 1.2
> >> GEOS: 3.0.0
> >> _______________________________________________
> >> postgis-users mailing list
> >> postgis-users at postgis.refractions.net
> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
> > geos-devel mailing list
> > geos-devel at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geos-devel
