[postgis-users] Rounding the angle of the polygon
Attila Csipa
plists at prometheus.org.yu
Fri Jan 18 06:26:46 PST 2008
On Thursday 17 January 2008 09:32:08 Witteveen, Eduard wrote:
> Is there a way to round the angle of the corners to 90 degrees of a
> polygon, where the corner is between 85 and 95 degrees? If this can't be
> done in (pl)sql, what would be "the way" to do this?
From what you say this won't be easy - you can't change the angles
of 'corners' unless you are altering the coords of the points (if you want to
preserve straight sides for your polygons, that is). And if ARE changing the
coordinates of the points, can you decide which points are on correct
locations and which ones are skewed ?
