[postgis-users] How to get the centerline of a polygon?
Kevin Neufeld
kneufeld at refractions.net
Fri Jan 18 08:35:55 PST 2008
Eric,
Are you perhaps after generating voronoi skeletons with your areas?
If so, you may be interested in the free Skeletonizer Utility (SK)
plugin for JUMP that we developed here at Refractions a while back.
http://www.jump-project.org/project.php?PID=SK&SID=OVER
This utility will generate voronoi skeletons (center lines) given a
polygon and a set of input/output points.
The attached picture shows the results using a long narrow lake and
stream input/output points as input.
Cheers,
Kevin
Kevin Neufeld
Software Developer
Refractions Research Inc.
300-1207 Douglas St.
Victoria, B.C., V8W 2E7
Phone: (250) 383-3022
Email: kneufeld at refractions.net
Eric Yu wrote:
> Hi,
> Suppose I have a long shaped polygon, like river area or the road,
> is it possible to get the centerline of the area using PostGIS?
> Or with other GIS library/software? I searched and tried but failed to
> get any solution.
> Thank!
> Eric
> postgis-users mailing list
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080118/514ba0c7/attachment.png>
