[postgis-users] I've got a silly question about performance
easpengren
phat-ass at thinkheavyindustries.com
Fri Jan 18 12:07:37 PST 2008
Great.
This is all great advice. I hadn't thought of the area(), st_intersection()
trick.
Some parcels do cross over into more than one precinct.
Eric
Josh Livni-3 wrote:
> Well, and again assuming he doesn't mind getting the list of parcels
> whose centroids intersect each district rather than the list of parcels
> that intersect each district, checking for point-polygon intersection is
> going to be faster than checking for polygon-polygon intersection. So
> for speed purposes it's probably a good way to go.
> For a first pass, after ensuring there is a gist index on the centroid
> (or in this case point-on-surface - tho I'm not sure why), I would
> expect the following to be faster than the equivalent query w/the full
> polygons rather than the points:
> AND election.the_geom && ST_pointonsurface(parcel2.wkb_geometry)
> AND
> ST_distance(election.the_geom,ST_pointonsurface(parcel2.wkb_geometry)) = 0
> And if you really needed speed, adding a new geometry field with the
> points precalculated and using that in the second line would make things
> even faster.
> -Josh
> Chris Hermansen wrote:
>> If you want a list of parcels in each precinct, why are you first
>> creating points? That's just going to add extra - unnecessary -
>> geoprocessing.
>> Try st_intersects() and st_intersection().
>> If you are concerned your parcels overlap more than one precinct, get
>> the area() of each intersection(), get the max() of that, and group by
>> your other variables.
>> Gregory Williamson wrote:
>>> The GIST index is the one you want / need for spatial operations. Make
>>> sure that you ANALYZE <tablename>; after creating the index or
>>> changing the data much (rule of thumb is maybe 10% but analyze is a
>>> fast and fairly low impact operation).
>>> The ST_ functions usually (always?) invoke the && operator (which is
>>> the spatial operator which will use the GIST indexes); they are
>>> wrapper for the underlying functions.
>>> Posting your information [type of hardware, OS, postgreSQL and postGIS
>>> versions, table structure and indexes, tables sizes, the query itself
>>> and the results of EXPLAIN ANALYZE <query>] to the PostgreSQL
>>> performance mail list might be worthwhile if this list doesn't help
>>> enough.
>>> Greg Williamson
>>> Senior DBA
>>> Globexplorer LLC, a company owned by DigitalGlobe
>>> -----Original Message-----
>>> From: postgis-users-bounces at postgis.refractions.net on behalf of
>>> easpengren
>>> Sent: Thu 1/17/2008 12:02 AM
>>> To: postgis-users at postgis.refractions.net
>>> Subject: Re: [postgis-users] I've got a silly question about performance
>>> OK, I think I've got that. When I imported these shape files into the
>>> database, an index was created. I added a Gist index to both to see what
>>> would happen. Will that cause a problem?
>>> I do not understand Indices at all. I'll have to read up on them.
>>> We'll see how these things come out. I would like to have something
>>> usable
>>> in the next day or two.
>>> I'll likely end up creating a view of this query. Again, I'm still
>>> figuring
>>> this out. Speed is really quite important for me. I don't have the most
>>> powerful machine doing this stuff (more RAM will likely show up this
>>> week).
>>> What I'd like to do is make sure the software is working as
>>> efficiently as I
>>> can get it.
>>> As I type this, I seem to have gotten a much quicker response from the
>>> server.
>>> Wow.
>>> Eric
>>> Brent Wood-2 wrote:
>>>> --- easpengren <phat-ass at thinkheavyindustries.com> wrote:
>>>>> I'm still getting the hang of some of the finer points of creating
>>>>> queries in
>>>>> PostGIS, as is probably obvious with my last post.
>>>>> I've two tables, parcel2 that is a collection of parcels in a
>>> county and
>>>>> a
>>>>> table election, which is a table of voting precincts in the same
>>> county.
>>>>> I'd
>>>>> like to select all of the parcels in each precinct.
>>>> That query looks OK, but if parcels can be split across precincts,
>>> then it
>>>> won't necessarily give the correct answer.
>>>>> I have this query:
>>>>> select precinct, sit_st_num, sit_st_dir, sit_st_nam, sit_st_typ,
>>>>> city_code
>>>>> from election, parcel2 where ST_contains(election.the_geom,
>>>>> ST_pointonsurface(parcel2.wkb_geometry));
>>>>> This gets the job done, but it's very slow. What can I do to speed
>>>>> this
>>>>> up?
>>>> See the PostGIS docs about creating spatial indices on the geometry
>>>> columns in
>>>> your two tables.
>>>> http://postgis.refractions.net/docs/ch04.html#id2761842
>>>> http://postgis.refractions.net/docs/ch04.html#id2761985
>>>> If you have, or if you create them, then you need to modify your
>>> query to
>>>> use
>>>> them:
>>>> .... where election.the_geom && parcel2.wkb_geometry and ST_contains
>>>> as described in:
>>>> http://postgis.refractions.net/docs/ch04.html#id2762121
>>>> Hope this helps...
>>>> Brent Wood
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> View this message in context:
>>> http://www.nabble.com/I%27ve-got-a-silly-question-about-performance-tp14910258p14913339.html
>>> Sent from the PostGIS - User mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/I%27ve-got-a-silly-question-about-performance-tp14910258p14957787.html
