[postgis-users] Pipeline Data Model
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Tue Jan 22 12:17:16 PST 2008
Just as an update, I have submitted a project for sourceforge hosting approval, called "Environmental Data Models", short name "envirodata".
Perhaps the "envirodata" moniker is too restrictive, maybe, ogcdata would be better. Since I didn't get any feedback, I just called it something that I thought was relevant.  Any suggestions would be welcome.
I will mail more when I get approval.
r.b.
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Burgholzer,Robert
Sent: Monday, January 14, 2008 12:26 PM
To: PostGIS Users Discussion; PostGIS Users Discussion
Subject: RE: [postgis-users] Pipeline Data Model
OK,
I will begin the process of starting a sourceforge project to house the data models and supporting SQL functions, etc.  It would be great if Abe can facilitate some space for some of this as well, I think that the sourceforge is a good way to go about managing contributions and so forth, but if geoloaded.com could host some demos/case-studies, that would be really great (if that is what you have in mind).
What would we be trying to do, putting together/porting some data models for this kind of pipeline/hydro data? What would it be called, i.e., what would one call a generic class of data models that would encapsulate that which we are working on?
r.b.
From:   postgis-users-bounces at postgis.refractions.net on behalf of Abram Gillespie
Sent:   Mon 1/14/2008 11:35 AM
Cc:
Subject:        Re: [postgis-users] Pipeline Data Model
All,
These are all very interesting ideas.  I have a proposal - I've been
meaning to get a site running at geoloaded.com (nothing there ATM),
and though sharing data models isn't *specifically* the idea I had in
mind, it's very much in the spirit of what I intend to do.  I'm happy
to host anything the group manages to put together.  I'm not clear on
the EULA of the data model I currently have in my possession, but if I
can, I will post my results at the site as soon as I have something.
R.B.,
I'm swamped right now but will be in touch as soon as I have a moment.
 I live at 14th & Main BTW.  Small world indeed.
-Abe
On Jan 14, 2008 7:47 AM, Burgholzer,Robert
<rwburgholzer at deq.virginia.gov> wrote:
> We might think to do a little divide and conquer strategy on the database that Abe has, perhaps recruiting a group of individuals to each sign up for a handful of tables to convert to postgres, and then upload them all to a sourceforge repository.
> r.b.
> From:   postgis-users-bounces at postgis.refractions.net on behalf of Chris Hermansen
> Sent:   Sun 1/13/2008 12:47 PM
> Cc:
> Gustavo makes a great point here.
> Having worked with workstation ArcInfo for many years, I have a kind of
> "conceptual library" of how to do common tasks in the field in which I work.
> As I use PostGIS I have to re-learn this "conceptual library", based on
> the building blocks defined by OGC.  I have to say that my general
> impression is that the OGC geoprocessing model sometimes necessitates
> some pretty complicated SQL to achieve what is relatively
> straightforward in workstation ArcInfo, an example being given in the
> Wiki on geometrically combining partially overlapping polygon geometries
> so as not to generate null geometries where only one or the other input
> geometry exists.
> In our company, we are (slowly) working on some documentation that
> demonstrates how to accomplish "model tasks" in PostGIS.
> One of the biggest challenges we face (and would face on platforms other
> than PostGIS as well) is cleaning up the cruft coming in from all the
> nasty shapefiles floating around out there.  For example,
> self-overlapping polygon geometry, gaps between polygons that aren't
> supposed to be there, tiny noise components arising from unfiltered
> GPS-source data.  I could go on :-)
> Another area of challenges is where we want a different geometric
> outcome than provided for in the OGC standard.  A simple example is
> first being surprised by, then dealing with, degenerate geometries or
> composite geometries generated by what seem to be fairly straightforward
> geometric operations.  A more complex example is the example given above
> - most of the time, when we overlay partially overlapping geometries, we
> don't want null geometries as a result in locations where only one or
> the other input geometry exists, rather we want whatever geometry exists
> with the appropriate attributes set to null.
> Another is creating new geometries from components - geometries from
> text files, polygons from lines and points, etc.
> Two things I see discussed on this list that could be of interest in the
> future are topology and time travel.  Way back when PostgreSQL was just
> Postgres I did some work with time travel; I can see real potential in
> the concept, for example as a framework for managing and reporting on
> environmental certification.  However that's a big design issue even
> with time travel working :-)  With respect to topology, I'm surprised
> how little I miss it; though there are people in our offices who find
> it's the only solution for fixing up really nasty shape files; ie
> convert the data to coverages and bang away at them using the polygon
> topology until either nothing is left or the problem is fixed.
> Anyway.  Whether the approach to sharing this kind of info is through
> separate projects or just a bit more input to the PostGIS wiki, it seems
> pretty worthwhile to me.
> Gustavo Ces wrote:
> > You can´t export a geodatabase ( i supose your model is just that) by
> > odbc, because the geometric logic is not transfered ( can you export a
> > geodatabase in arcgis to postgis?) I think you have to rewrite the
> > model, adapting it to postgis. Is a hard work, but the you can use the
> > postgresql full potential ( triggers, views, etc.. ) to make your
> > model more powerfull, smaller and dynamic.
> > In my experience, this work simplifies the model, and you can make it
> > "real-time", user adapted, etc...
> > I´ve posted a long time ago a question about postgis models. I imagine
> > all postgis community members working alone, creating complex
> > functions and schemas to solve their problems and... reinventing the
> > wheel. Perhaps it´s time to create especific projects to create ( or
> > traduce ) schemas and functions for various cases. I know the wiki,
> > but i think in environmental members creating  schemas, functions to
> > solve environmental questions( for instance). At this time each of
> > them has to walk his way alone ...
> > It´s just an opinion :)
> > Gus
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Regards,
> Chris Hermansen · mailto:clh at timberline.ca
> tel:+1.604.714.2878 · fax:+1.604.733.0631
> Timberline Natural Resource Group · http://www.timberline.ca
> 401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
> C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080122/95cb67dd/attachment.html>
