[postgis-users] Faster point polygon query
Paul Ramsey pramsey at refractions.net
Wed Jan 23 15:04:26 PST 2008
The index-caching trick appears to be on both ST_Within and
ST_Contains.  It was added to the code at 1.3.0.
P
On 23-Jan-08, at 2:26 PM, Martin Davis wrote:
> Some thoughts:
> - ST_Distance is likely to be slow, since it does not do any
> optimizations
> - ST_Within was recently optimized to include a fast point-in-
> polygon test.  Are you using a recent version of PostGIS?  It's
> funny that it isn't showing an effect in your test.  Perhaps you
> could try the same query using a non-spatial test, to get a
> baseline for how long the query takes to simply rip all the data
> off disk and run the join.
> - does ST_Contains produce the same performance?
> Also, we're currently working on "Prepared" (Cached) versions of
> various spatial predicates, including ST_Within.  Would it be
> possible for us to get a sample subset of your data to test and see
> whether the new code will improve things?
> Dan Erikson wrote:
>> I need to relate two spatial datasets.  One dataset is a point
>> dataset (~200 Million records), the other is a polygon dataset
>> (~500,000 records).  The result of these queries is to be a non-
>> spatial table listing the id's ("tid" in this case) from each
>> table where there is a spatial join.  I have tried both ST_Within
>> and ST_Distance, and both queries are incredibly slow (> 100
>> hours).   Running on a very capable server.  Any ideas on faster
>> methods to complete this query?
>> Thanks!
>> CREATE TABLE public.step2 as
>>    (SELECT mp.pntgrid_10_tid AS pntgrid_10_tid,
>>        vri.tid AS vri_tid
>>    FROM grids.tbl_mtsa_pnts mp, vri.tbl_vri vri
>>    WHERE mp.geom && vri.geom
>>        AND ST_Within(mp.geom, vri.geom));
>>        vri.tid AS vri_tid
>>        AND ST_Distance(mp.geom, vri.geom) = 0);
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
> postgis-users mailing list
