[postgis-users] Maintain length and precision for numneric fields in pgsql2shp and shp2pgsql
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Thu Jan 24 00:26:49 PST 2008
Paul Ramsey wrote:
> On Jan 23, 2008, at 3:39 AM, Peter Hopfgartner wrote:
>> we were looking at the tables generated by shp2pgsql. As it seems,
>> numeric(m, 0) is mapped, if possible to integers, and numeric(m,n) is
>> mapped to numeric.
> Do you mean, mapped to float?
Usually yes, but in our case the original column was a a numeric(19,
11), so the if statement in line 559 choses numeric instead of float8,
which makes perfectly sense.
>> We would like to optionally maintain the numeric length and precision
>> for our data imports. Looking at shp2pgsql.c,  this should be rather
>> simple. Basically, we could add an option, let's say '-K' for keep
>> precision, and modify the code around line 550.
> This is possible. You need to be aware of the *massive* performance
> penalty that comes with using numeric instead of integer/float.  As
> long as you are clear on that, it's certainly acceptable.
Yes, this is true. In almost all cases the current behavior of shp2pgsql
and pgsql2shp is preferable. But in this specific project we are working
on, the customer, a public administration, insists on data formats.
> Since we have -i for "force to integer" how about -n for "use numeric
> for all numbers"?
Sounds good.
>> A similar change could be done for pgsql2shp, modifying the SQL
>> query, which gets the type information from PostgreSQL and changing
>> the code generating the dbf header.
>> If such a change is welcomed, we can try to have it done soon.
>> Regards,
>> Peter Hopfgartner and Sergio Segala
>> R3 GIS
>> http://www.r3-gis.com
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Regards,
Peter & Sergio
R3 GIS
