[postgis-users] Spatial query Help: points not in set of polygons
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jan 24 06:53:08 PST 2008
Regina,
Thank you! I thought this was a LEFT JOIN situation, but my brain just
was not parsing the problem. I used the 2nd query and it seems to be
working great.
I'm runnning an older version:
"POSTGIS="1.1.1" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
USE_STATS"
"PostgreSQL 8.1.8 on x86_64-pc-linux-gnu, compiled by GCC cc (GCC) 3.3.5
(Debian 1:3.3.5-13)"
So I dropped the "ST_", but I am getting a NOTICE:
NOTICE: LWGEOM_gist_joinsel called with incorrect join type
CONTEXT: SQL statement "select a.file, a.id, a.name
from points a LEFT JOIN polygons b
ON (a.the_geom && b.the_geom and distance(a.the_geom, b.the_geom) =
0.0)
where b.the_geom IS NULL"
Do you know why? Is this something that I need to worry about?
Your most excellent support of this list is always noticed by this
reader. Thank you.
Best regards,
-Stephen Woodbridge
Obe, Regina wrote:
> SELECT a.*
> FROM point a LEFT JOIN polygons b
> and ST_distance(a.the_geom, b.the_geom) = 0.0)
> WHERE b.the_geom IS NULL
> or
> SELECT a.*
> ON ST_Within(a.the_geom, b.the_geom)
> I think the second one should be more efficient, but I haven't done any
> benchmarks.
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Stephen Woodbridge
> Sent: Wednesday, January 23, 2008 10:27 PM
> To: PostGIS Users Discussion
> Subject: [postgis-users] Spatial query Help: points not in set of
> polygons
> Hi all,
> I'm drawing a blank on setting up a query for this.
> I have a tables points and a table of polygons. I need to find all the
> points that are not in any of the polygons.
> select a.*
> from points a, polygons b
> where a.the_geom && b.the_geom
> and distance(a.the_geom, b.the_geom) > 0.0;
> The problem with this is that if a point is in polygon A it will have a
> distance to polygon B, so this in no good.
> I thought of doing something like:
> select * from points
> where distance(the_geom, union((select the_geom from polygons))) >
> 0.0;
> or
> where distance(the_geom, collect((select the_geom from polygons))) >
> 0.0;
> So is there a better way to do this. Seems like there should be. If not
> which of these would you suggest.
> Thanks,
> -Steve
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
