[postgis-users] Hints or tips on Large Intersect
niels hoffmann
nielslcr at gmail.com
Thu Jan 24 15:46:13 PST 2008
I am fairly new to Postgis so I like some feedback whether I am going
through the right moves.
I am trying to create a new table with the intersected results from two
input polygon tables.
Both tables are in NZMG (2193) the first table has 100000+ records, the
second table has 400000+ records.
The query I am using is:
Create table ablc_pol with OIDS as
SELECT intersection(a.geom, l.geom) as intersect_geom, a.*,
l."CLASS",l."NAME", l."REPLID"
from first_table a, second_table l
Where a.geom && l.geom
AND intersects(a.geom, l.geom);
Currently this query is taking >200 hours before I cancelled it because I
wasn't sure it would ever end. However, running it on a small subset showed
satisfactory results...
I am using version 1.2 on Windows.
Does it matter which table I put first in the query or would the optimizer
take care of that?
Cheers,
Niels
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080125/d173fb2d/attachment.html>
