[postgis-users] Meant to ask for PostGIS/Google Maps API using Python
Josh Livni
josh at umbrellaconsulting.com
Fri Jan 25 08:58:23 PST 2008
There's two ways to overlay data from PostGIS into Google Maps. As an
image overlay (eg WMS), or as vector overlays (if you don't have tons of
complex data in one view).
WMS:
Assuming you are gonna use Google Maps proper, versus OpenLayers (which
would make things easier), check out wms236.js for a simple javascript
that makes it reasonably easy to take your WMS and overlay it in Google
Maps. Note that either way, Google uses an 'odd' projection
(http://spatialreference.org/ref/user/google-projection/) so your WMS
should be output in that. However if you are just working with a
localish area not near the poles, you can probably get away with
EPSG:4326 for a reasonable close overlay.
A slightly modifed wms236.js called wms_spherical.js that uses this
projection is in use at http://seattleurbannature.org/Survey/ihm.html
(which has all its source data in PostGIS). Again, if you use
OpenLayers you don't have to deal with this extra bit, but either way
you do still need your WMS to output in a projection that overlays nicely.
Vectors:
This one's easy: use FeatureServer (hey - it's even in python). I'm
not covering how to parse the GeoJSON and create vector overlays in
Google Maps here, but that's quite well documented. Or just load the
KML directly. In OpenLayers, the GeoJSON output is easy to turn into
vector overlays.
Cheers,
-Josh
PS digest subscribers can get up to the minute reporting online:
http://postgis.refractions.net/pipermail/postgis-users/ or
http://www.nabble.com/PostGIS-f1221.html
PPS All the above is just regarding a simple map, no additional
framework. Did you say you wanted an actual full fledged framework of
some kind? Check GeoDjango maybe - I think they have Google Map
templates now.
dnrg wrote:
> Python is my language of choice and I'm sticking with
> it. So, are there any PostGIS/Google Maps API
> integration tutorials using Python?
> Python seems to provide the best bang for the buck
> FOSS GIS-wise. And my brain can only store so much
> syntax.
> I only subscribe to the Digest version of this list;
> sorry if my question has already been answered.
> I am jazzed about the idea of PostGIS/Google Maps
> integration using Python. Would love to see some
> working online examples as well.
> Dana
> ____________________________________________________________________________________
> Looking for last minute shopping deals?
> Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
> postgis-users mailing list
