[postgis-users] newbie question
Paul Ramsey
pramsey at refractions.net
Fri Jan 25 22:06:32 PST 2008
Or the more succinct and modern
SELECT the_geom, zone
FROM r_zones
WHERE
ST_Contains(the_geom,GeomFromText('POINT(7644373.465626
687692.342075)', 2838));
On 25-Jan-08, at 8:14 PM, Stephen Woodbridge wrote:
> Try:
> FROM r_zones
> WHERE
> setsrid(makepoint(7644373.465626, 687692.342075), 2838) && the_geom
> and within(setsrid(makepoint(7644373.465626, 687692.342075),
> 2838), the_geom);
> Now this assumes that the_geom of r_zones is also in srid 2838. If
> not you will need to project the point into whatever srid that
> r_zones is in.
> HTH,
> -Stephen Woodbridge
> http://imaptools.com/
> Thomas Crosslin wrote:
>> I’m a new PostGIS/PostgreSQL user.
>> I’ve successfully set up my database and uploaded a few shapefiles
>> to play with.
>> I want to do some spatial queries and I’m having some difficulty.
>> I’d like to extract the polygon that a point intersects –
>> actually I really want to be able to intersect several layers at
>> once with a given point and return the values from a particular
>> field from each layer. But I decided to start with one layer. So
>> the table is called “r_zones” (it is an imported shapefile) and
>> the field I want information returned from is called “zone”. So
>> what I want is to know what “zone” the point falls within. I’m
>> using PgAdmin (v1.6.2) to query my database, Windows, Postgres8.2,
>> PostGIS 1.3.1.
>> So I’ve tried a basic query like this:
>> FROM r_zones
>> WHERE GeomFromText('POINT(7644373.465626 687692.342075)', 2838)
>> I know the WHERE statement is incorrect, I’ve tried several
>> variants looking at the docs (like using a distance based query
>> and others) but cannot make a successful query. Where am I going
>> wrong?
>> Any help appreciated.
>> -Thomas
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
