[postgis-users] Combined MULTIPOLYGON from subselect on column containing MULTIPOLYGON?
Ben Jubb
benjubb at refractions.net
Mon Jan 28 08:59:16 PST 2008
Did you try using the aggregate ST_Union to merge your geometries?
b
Marcus Jenkins wrote:
> Hi
> I'm trying to make a (new, larger) multipolygon from a number of rows
> that are selected using an aggregate function ST_Collect. The problem
> is that the ST_Collect creates a geometrycollection which I can't work
> out how to merge into a new multipolygon, even though the source
> column only contained multipolygon. I've RTFM a few times...
> ...help?!
> My current insert statement looks something like this - I get no
> error, but the output is null in the output column.
> insert into my_output_table (id, the_geom, debug_text) select s.id,
> ST_MPolyFromText(ST_AsText(ST_Collect(s.the_geom))),
> ST_AsText(ST_Collect(s.the_geom)) from my_source_table s group by id;
> The debug_text column gets filled with lots of nice WKT of
> GEOMETRYCOLLECTION, but we kind of expected that already ;-)
> Any clues greatly appreciated. Otherwise I will be forced to do
> something horrible in Perl like do the select, dismember each
> MULTIPOLYGON record in the source table grouped as per the select
> above and then craft WKT to make an insert statement to populate my
> output table. /Surely/ I don't have to resort to this kludgery?
> Regards
> Marcus
> postgis-users mailing list
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080128/430c884f/attachment.vcf>
