[postgis-users] shp2pgsql and shx
Andrea Maschio
andrea.maschio at gmail.com
Mon Jan 28 15:44:16 PST 2008
So the result seems to be actually you can't import Shape files w/out
their indexes.
Thanks a lot
Andrea Maschio
Il giorno 29/gen/08, alle ore 00:27, P Kishor ha scritto:
> On 1/28/08, Martin Davis <mbdavis at refractions.net> wrote:
>> Actually the SHP and DBF files are "linked" simply by the order of
>> the
>> records in the files. So the SHX file isn't needed to read the data.
>> It is only required if you want to read the data through the index.
> You are absolutely correct on both counts. I realized my misleading
> message after I had sent it as I have been happily reading DBF files
> and modifying them using Perl directly and the parent Shapefile has
> been ok. Thanks for pointing it out.
> To the OP -- one of them (between SHP and DBF) is indexed starting at
> 0 and the other one starting at 1 (I always forget which one is
> which).
> Perhaps shp2pgsql does exactly that... read the attributes for each
> shape via the index.
>> P Kishor wrote:
>>> On 1/28/08, Andrea Maschio <andrea.maschio at gmail.com> wrote:
>>>> Hello all, is it normal that trying to convert a shape into sql
>>>> with
>>>> shp2pgsql I have an error stating that i need the .shx index
>>>> file? Is there
>>>> an option for importing having only the .shp file?
>>>> Thanks
>>>> Andrea Maschio
>>> The .shx file is the link between the geometry (.shp) and the
>>> attributes (.dbf). These three are the minimum necessary
>>> components of
>>> an ESRI Shapefile. If your .shx/.dbf are missing then you have any
>>> incomplete Shapefile.
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Martin Davis
>> Senior Technical Architect
>> Refractions Research, Inc.
>> (250) 383-3022
> Puneet Kishor http://punkish.eidesis.org/
> Nelson Institute for Environmental Studies http://www.nelson.wisc.edu/
> Open Source Geospatial Foundation (OSGeo) http://www.osgeo.org/
