[postgis-users] Geometry appears empty
geoffi
geoff.innes at ngis.com.au
Tue Jul 1 17:12:40 PDT 2008
I have translated some polygon data into a PostGIS table using FME. The
translation was successful with no errors reported. All the records appear
in the PostGIS table (using the pgAdminIII application) except for about 90%
of the geometries (see image below).
http://www.nabble.com/file/p18227858/table.jpg
However, using the FME Universal Viewer all records are displayed with their
correct geometry as I would expect.
What is causing the Geometry column in the table to appear empty?
Is there a setting in PostGIS to force the data to be visible in the
pgAdminIII application?
Attempts to generate a WMS from this table using GeoServer only displays
those records that appear to have geometry.
Performing a similar exercise using point geometries, there was no problem.
View this message in context: http://www.nabble.com/Geometry-appears-empty-tp18227858p18227858.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
