[postgis-users] Re: Postgis Hosting Recommendations Update?
Obe, Regina
robe.dnd at cityofboston.gov
Thu Jul 3 08:11:27 PDT 2008
Randy,
Thanks - I've added it to the list. I created a PostGIS Hosters section
in the Wiki to catalog all these. Anyone feel free to add to it.
http://postgis.refractions.net/support/wiki/index.php?PostGISHosters
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Randy George
Sent: Thursday, July 03, 2008 10:58 AM
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] Re: Postgis Hosting Recommendations Update?
I guess hosting options become more important as MS SQL Server
2008
adds spatial capability, since a lot of low cost shared hosting supports
SQL
Server options.
I have generally used dedicated/collocated myself, but going
forward
I use the Amazon AWS-EC2.
http://developer.amazonwebservices.com/connect/kbcategory.jspa?categoryI
D=84
Some advantages of AWS virtual service:
1) cost effective relative to dedicated/collocated (but not in same
range as
the $20/mo shared services)
2) same control as dedicated
3) hardware scaling options multicore/32/64
4) innumerable OS options in the AMI list
5) unlimited Linux software options (not just basic PostGIS - Java, gcc,
Apache, JBoss, GeoServer, Gdal/ogr, MapServer, GRASS ... great for
custom
service chains)
6) lots of scaling vectors including auto-scaling options
7) additional cloud tech like S3, SimpleDB, and SQS suitable for complex
projects
The Ubuntu ami has a very easy to use package management tool, apt-get.
The
apt-get database includes fairly recent PostGIS/PostgreSQL builds, but
you
can build the nightly release if you need to.
Disadvantage for Windows users is that AWS is a Linux only world.
Shared hosting Dedicated hosting AWS virtual
$10-$50 $50-$500 $73,$146,$292,$584
Randy
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Obe,
Regina
Sent: Thursday, July 03, 2008 5:51 AM
To: PostGIS Users Discussion
People ask me this question every once in a while, and I never quite
know what to tell them since I host my own and any Linux/windows host
works for me since I always get dedicated hosting and don't rely on the
technical abilities of the hoster.
I think it might be a good idea for us to have a section in the wiki
devoted to list of PostGIS hosters (at least for starting off just so
users can contribute their favorites) and then maybe have this section
referenced from the PostGIS support page.
I think when you are at least starting off its often a prime decision
factor which hosting companies support PostGIS. I suspect we loose a lot
of business to MySQL even though their GIS implementation is vastly more
inferior to PostGIS because it has GIS support out of the box and every
Linux host on the Planet supports them. Same I suspect will be true for
SQL Server 2008 when it comes out.
I know PostgreSQL has a section devoted to hosters - but that doesn't
really tell you if they support PostGIS or not or even what version of
PostgreSQL they are running
http://www.postgresql.org/support/professional_hosting
Thanks,
Regina
William Temperley
Sent: Thursday, July 03, 2008 7:32 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Re: Postgis Hosting Recommendations Update?
Sean Montague wrote:
> I've been with http://hub.org/ for several years, I like them a lot.
> Richard Greenwood wrote:
>> On Tue, Jul 1, 2008 at 10:08 AM, Donald Ijams <dsijams at gmail.com>
wrote:
>>> I'm searching for a Postgis enabled web host and noticed the 2006
discussion
>>> of this topic on this list. Is there a more recent discussion that
I've
>>> missed? Is anyone on this list happy with their Postgis enabled web
host?
>>> Thanks.
>> I am happily using Micro Resources http://mrcc.com/ but I am not sure
>> about Postgis support.
www.webfaction.com have postgis support. I've used PostgreSQL with
them which has been excellent. I haven't enabled PostGIS, though they
said just ask and they'd enable it.
Cheers,
Will
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
