[postgis-users] import large multipolygon
Kevin Neufeld kneufeld at refractions.net
Fri Jul 4 13:22:57 PDT 2008
No, I think astext() is returing the geometry, but i think you're seeing
a large wrap around as postgres tries to add the column title to your
resultset.
If you're using psql, try this.
postgis=# \t
Showing only tuples.
postgis=# SELECT ST_AsText(the_geom) FROM testtable;
  MULTIPOLYGON(((-80.1547175872617 42.7394116625306,...
Cheers,
Kevin
sub3 wrote:
> Interesting, I run the same query & get your same results... so that shows
> the object is there.  So why would astext(the_geom) return nothing?  Maybe
> it doesn't return something when the size is too large?
> Thanks!
> Kevin Neufeld wrote:
>> I don't have any problems loading your sql file into my database
>> (running PG8.3.3, PGIS 1.3.3)
>> postgis=# \i testtable.sql
>> psql:testtable.sql:3: NOTICE:  CREATE TABLE will create implicit
>> sequence "testtable_gid_seq" for serial column "testtable.gid"
>> psql:testtable.sql:3: NOTICE:  CREATE TABLE / PRIMARY KEY will create
>> implicit index "testtable_pkey" for table "testtable"
>> CREATE TABLE
>>                        addgeometrycolumn
>>   kneufeld.testtable.the_geom SRID:-1 TYPE:MULTIPOLYGON DIMS:2
>> (1 row)
>> postgis=# select ST_GeometryType(the_geom), ST_IsValid(the_geom),
>> ST_NPoints(the_geom) from testtable;
>>   st_geometrytype | st_isvalid | st_npoints
>>   ST_MultiPolygon | t          |       8655
>> (1 row)
>> -- Kevin
>> sub3 wrote:
>>> Hi,
>>> I am having a problem.  I convert a shp file using shp2pgsql.  One of the
>>> multipolgons is very large (line is about 277k characters long).  After I
>>> import into postgresql, this geometry is empty.
>>> No error from postgis.
>>> No error from postgresql.
>>> I am only making a guess that it is the line size, I am not sure.  Is
>>> there
>>> a setting which would fix this?
>>> Thanks for any help.
>>> Attached is the .sql script.
>>> http://www.nabble.com/file/p18285042/testtable.sql testtable.sql
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
