[postgis-users] ST_Translate
Bob Pawley
rjpawley at shaw.ca
Wed Jul 9 08:39:45 PDT 2008
Hi Regina
Following is the query I am using.
The shapefile is also attached if any one wants to try it.
The shape was converted from a DXF file with the default SRID.
Bob
insert into entity (the_geom, position)
select
st_translate (public.process.the_geom,
st_x (st_centroid(spatial_ref.the_geom)) -
st_x (st_centroid (public.process.the_geom)),
st_y (st_centroid(spatial_ref.the_geom))-
st_y (st_centroid (public.process.the_geom))), ('i')
from spatial_ref, process
where spatial_ref.position_ = '1' ;
----- Original Message -----
To: "'PostGIS Users Discussion'" <postgis-users at postgis.refractions.net>
Sent: Wednesday, July 09, 2008 12:11 AM
Subject: RE: [postgis-users] ST_Translate
> Bob,
> Doesn't quite make sense to me why translating before ST_Union would cause
> distortion if you are translating all the same amount.
> What is the SRID of the data you are translating and what does your
> translate query and union query look like?
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob
> Pawley
> Sent: Tuesday, July 08, 2008 5:30 PM
> To: PostGIS Users Discussion
> Subject: [postgis-users] ST_Translate
> I've imported a shapefile that requires six rows in the table.
> When I translate that shape, of six rows, to another location the shape
> becomes distorted.
> When I collect the six rows by using ST_Union, then translate the single
> row
> to the new position, there is no distortion.
> Is there a method of using ST_Translate, without also using ST_Union, and
> still avoid the distortion of the shape??
> I need the geometries of the shape separate to be able to identify the
> parts of the shape I need. I seem to lose this informaion when I employ
> ST_Union.
> Bob
> postgis-users mailing list
Name: ButterFly Valve.shx
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080709/7af78d1c/attachment.obj>
Name: ButterFly Valve.dbf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080709/7af78d1c/attachment-0001.obj>
Name: ButterFly Valve.shp
Type: application/shapefile
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080709/7af78d1c/attachment.bin>
