[postgis-users] Group intersecting lines
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Jul 13 18:54:56 PDT 2008
Shane Butler wrote:
> Dear all,
> Can anyone offer some advice on how to group lines together that
> intersect? What I would like to achieve is a grouping where all
> connected lines are added to the one group and a disconnected set of
> connecting lines would be added to another group (and so on). Can I
> do this using a GROUP BY clause?
If you are trying to identify say all roads the are networked on an
island as one group and all lines that are networked on the mainland as
a separate group? Then no you can not. I believe you will need to look
at some algorithms in "graph theory" to do that.
You can use DFS (Depth First Search) to generate graphs of your nodes
and from that identify the separate "forests" in your data.
I would recommend getting this book:
http://www.google.com/search?hl=en&q=%22graph+algorithms%22+sedgewick&btnG=Google+Search
-Steve
