[postgis-users] Query that locks up system memory/disk usage
Paul Ramsey
pramsey at cleverelephant.ca
Mon Jul 14 16:49:10 PDT 2008
Break yourself of the subquery habit:
select a.* from a join b on (st_dwithin(a.the_geom,b.the_geom,50000))
where b.gid = 10;
On your process:
ps ax | grep postgres
Find the process id that is using all the CPU and just kill -9 it. The
glory of running a proper ACID database like PgSQL is that if you
don't like what it's doing, you can rip the power cord out of the
wall, and it'll still start up clean. (Do not try this with MySQL.)
P.
buffer((select b.the_geom
> where gid = 10),50000));
On Mon, Jul 14, 2008 at 4:33 PM, Mike Leahy <mgleahy at alumni.uwaterloo.ca> wrote:
> Hello list,
> I've run into some situations where running certain queries end up locking
> up all of my system's ram memory, with constant disk access. I can't cancel
> the query by hitting ctrl+c in the psql terminal, by restarting the service,
> or even killing the postmaster. I'm running on a fairly high end system, so
> it's not an issue with CPU power or available ram. Here's an example of
> what I did today that caused this:
> Table A is a table I imported from a tile index shapefile.
> Table B has several fairly large irregular polygons of different study
> areas.
> To get all of the polygons in Table A within a certain distance (50km) of
> one of the polygons in Table B, without giving it much thought I did the
> following:
> select * from a where st_intersects(a.the_geom,buffer((select b.the_geom
> I realize how wrong that is, as calculates the buffer for every tile it
> compares to...I should have done something like:
> select * from a where st_intersects(a.the_geom,(select b.the_geom where gid
> = 10)) or st_distance(a.the_geom,(select b.the_geom where gid = 10))<=50000;
> The problem is...I'm still waiting for the first query to either finish, or
> cancel, or something. In the meantime, postmaster is still using 99% of my
> memory, and the disk is still thrashing away (though CPU usage pretty much
> at 0). What's the best strategy to kill the previous query without having
> to shut down the entire server?
> Keep in mind that is just an example of how this can happen for me - I've
> had it happen in other more complex situations where it was less obvious
> what I was doing wrong in the logic of the query. I'm just wondering how I
> can recover from these sorts of mistakes without potentially damaging the
> database.
> Regards,
> Mike
> postgis-users mailing list
