[postgis-users] Query that locks up system memory/disk usage
Mike Leahy mgleahy at alumni.uwaterloo.ca
Mon Jul 14 22:15:06 PDT 2008
Kevin,
Perhaps I can cause the same situation (maybe tomorrow when the server
isn't occupied) and give this a try.  But I think I have already ruled
this out as an option.  When I would hit ctrl+c in the psql terminal,
I'd see a message that the query was being cancelled...then it would
just sit there and continue grinding away - unless there's a possibility
that maybe the ctrl+c command didn't actually reach the postgres
process, my guess is that maybe the attempt to rollback gracefully is
just as intensive.
Mike
Kevin Neufeld wrote:
> Paul, while "kill -9" will undoubtedly stop the current running query,
> it will also crash the entire database cluster since the shared memory
> will become corrupt.
> I recommend using a "kill -2" instead which is the same thing as issuing
> a ctrl^c while in the terminal program.  It may take longer since it has
> to rollback the transaction, but it will do so gracefully.
> -- Kevin
> Paul Ramsey wrote:
>> Break yourself of the subquery habit:
>> select a.* from a join b on (st_dwithin(a.the_geom,b.the_geom,50000))
>> where b.gid = 10;
>> On your process:
>> ps ax | grep postgres
>> Find the process id that is using all the CPU and just kill -9 it. The
>> glory of running a proper ACID database like PgSQL is that if you
>> don't like what it's doing, you can rip the power cord out of the
>> wall, and it'll still start up clean. (Do not try this with MySQL.)
>> P.
>> buffer((select b.the_geom
>>> where gid = 10),50000));
>> On Mon, Jul 14, 2008 at 4:33 PM, Mike Leahy <mgleahy at alumni.uwaterloo.ca> wrote:
>>> Hello list,
>>> I've run into some situations where running certain queries end up locking
>>> up all of my system's ram memory, with constant disk access.  I can't cancel
>>> the query by hitting ctrl+c in the psql terminal, by restarting the service,
>>> or even killing the postmaster.  I'm running on a fairly high end system, so
>>> it's not an issue with CPU power or available ram.  Here's an example of
>>> what I did today that caused this:
>>> Table A is a table I imported from a tile index shapefile.
>>> Table B has several fairly large irregular polygons of different study
>>> areas.
>>> To get all of the polygons in Table A within a certain distance (50km) of
>>> one of the polygons in Table B, without giving it much thought I did the
>>> following:
>>> select * from a where st_intersects(a.the_geom,buffer((select b.the_geom
>>> I realize how wrong that is, as calculates the buffer for every tile it
>>> compares to...I should have done something like:
>>> select * from a where st_intersects(a.the_geom,(select b.the_geom where gid
>>> = 10)) or st_distance(a.the_geom,(select b.the_geom where gid = 10))<=50000;
>>> The problem is...I'm still waiting for the first query to either finish, or
>>> cancel, or something.  In the meantime, postmaster is still using 99% of my
>>> memory, and the disk is still thrashing away (though CPU usage pretty much
>>> at 0).  What's the best strategy to kill the previous query without having
>>> to shut down the entire server?
>>> Keep in mind that is just an example of how this can happen for me - I've
>>> had it happen in other more complex situations where it was less obvious
>>> what I was doing wrong in the logic of the query.  I'm just wondering how I
>>> can recover from these sorts of mistakes without potentially damaging the
>>> database.
>>> Regards,
>>> Mike
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
