[postgis-users] Query that locks up system memory/disk usage
Kevin Neufeld
kneufeld at refractions.net
Tue Jul 15 09:38:58 PDT 2008
Ah yes, I've come across the same thing several times. For example, if
you use the pgstattuple module that comes with postgres and perform a
dead tuple query on at a table, it will scan the entire table, even
after issuing a ctrl^c or kill -2 ... but it will eventually terminate.
However, using top and killing queries using signal 2 has saved me many
times on a development box with several developers. I can quickly kill
that runaway query from a dropped JDBC connection without bringing down
the whole database. Usually the query stops right way and the rollback
is not very intensive, but it depends on what you are doing.
-- Kevin
Mike Leahy wrote:
> Kevin,
> Perhaps I can cause the same situation (maybe tomorrow when the server
> isn't occupied) and give this a try. But I think I have already ruled
> this out as an option. When I would hit ctrl+c in the psql terminal,
> I'd see a message that the query was being cancelled...then it would
> just sit there and continue grinding away - unless there's a possibility
> that maybe the ctrl+c command didn't actually reach the postgres
> process, my guess is that maybe the attempt to rollback gracefully is
> just as intensive.
> Mike
> Kevin Neufeld wrote:
>> Paul, while "kill -9" will undoubtedly stop the current running query,
>> it will also crash the entire database cluster since the shared memory
>> will become corrupt.
>> I recommend using a "kill -2" instead which is the same thing as
>> issuing a ctrl^c while in the terminal program. It may take longer
>> since it has to rollback the transaction, but it will do so gracefully.
>> -- Kevin
>> Paul Ramsey wrote:
>>> Break yourself of the subquery habit:
>>> select a.* from a join b on (st_dwithin(a.the_geom,b.the_geom,50000))
>>> where b.gid = 10;
>>> On your process:
>>> ps ax | grep postgres
>>> Find the process id that is using all the CPU and just kill -9 it. The
>>> glory of running a proper ACID database like PgSQL is that if you
>>> don't like what it's doing, you can rip the power cord out of the
>>> wall, and it'll still start up clean. (Do not try this with MySQL.)
>>> P.
>>> buffer((select b.the_geom
>>>> where gid = 10),50000));
>>> On Mon, Jul 14, 2008 at 4:33 PM, Mike Leahy <mgleahy at
>>> alumni.uwaterloo.ca> wrote:
>>>> Hello list,
>>>> I've run into some situations where running certain queries end up
>>>> locking
>>>> up all of my system's ram memory, with constant disk access. I
>>>> can't cancel
>>>> the query by hitting ctrl+c in the psql terminal, by restarting the
>>>> service,
>>>> or even killing the postmaster. I'm running on a fairly high end
>>>> system, so
>>>> it's not an issue with CPU power or available ram. Here's an
>>>> example of
>>>> what I did today that caused this:
>>>> Table A is a table I imported from a tile index shapefile.
>>>> Table B has several fairly large irregular polygons of different study
>>>> areas.
>>>> To get all of the polygons in Table A within a certain distance
>>>> (50km) of
>>>> one of the polygons in Table B, without giving it much thought I did
>>>> the
>>>> following:
>>>> select * from a where st_intersects(a.the_geom,buffer((select
>>>> b.the_geom
>>>> I realize how wrong that is, as calculates the buffer for every tile it
>>>> compares to...I should have done something like:
>>>> select * from a where st_intersects(a.the_geom,(select b.the_geom
>>>> where gid
>>>> = 10)) or st_distance(a.the_geom,(select b.the_geom where gid =
>>>> 10))<=50000;
>>>> The problem is...I'm still waiting for the first query to either
>>>> finish, or
>>>> cancel, or something. In the meantime, postmaster is still using
>>>> 99% of my
>>>> memory, and the disk is still thrashing away (though CPU usage
>>>> pretty much
>>>> at 0). What's the best strategy to kill the previous query without
>>>> having
>>>> to shut down the entire server?
>>>> Keep in mind that is just an example of how this can happen for me -
>>>> I've
>>>> had it happen in other more complex situations where it was less
>>>> obvious
>>>> what I was doing wrong in the logic of the query. I'm just
>>>> wondering how I
>>>> can recover from these sorts of mistakes without potentially
>>>> damaging the
>>>> database.
>>>> Regards,
>>>> Mike
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
