[postgis-users] contains syntax
jj.wag at gmx.de
jj.wag at gmx.de
Thu Jul 17 03:01:39 PDT 2008
Regina,
thank you very much!
with ST_Contains it works! I was working with an older POSTGIS-Version and
will update now.
But under the old version this syntax works too:
UPDATE standorte
SET lk = l.lk
FROM landkreise as l
WHERE
Contains(l.the_geom, standorte.the_geom);
I think it was the "s.the_geom" part
if I write "UPDATE standorte" it must be "standorte.the_geom"
Greetings + thanks
Jo
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Wednesday, July 16, 2008 1:07 PM
Subject: RE: [postgis-users] contains syntax
Jo,
Your update syntax should be
UPDATE standorte
SET lk = l.lk
WHERE
ST_Contains(l.the_geom,standorte.the_geom) = TRUE;
Note - your below query is not using indexes. If you are using Postgis
1.2.1 or above, use the new
ST_Contains instead (that will use indexes since it automagically adds
the && operator)
If you are using older PostGIS, then use
l.the_geom && s.the_geom AND Contains(l.the_geom, s.the_geom)
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
jj.wag at gmx.de
Sent: Wednesday, July 16, 2008 6:18 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] contains syntax
Hi all,
I have 2 tables:
1. table "landkreise" (polygon) with column "lk" (names of
administrative
borders (polygons))
2. standorte (point) with column "lk" (empty, I want to write the name
of
the administrative borders from the polygon-feature that contains the
point)
When I use following select-statement it seems to work:
SELECT l.lk FROM landkreise as l, standorte as s WHERE
contains(l.the_geom,s.the_geom) = TRUE;
When I want to update the column "lk" in table standorte allways the
same
name is written:
UPDATE standorte SET lk = l.lk FROM landkreise as l, standorte AS s
WHERE
What is wrong with my syntax?
Thanks
Jo
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
