[postgis-users] Postgis to ESRI shape file encoding problem
Ervin Ramonllari
ervin.ramonllari at hotmail.com
Fri Jul 18 05:54:37 PDT 2008
I tried that solution, but the result is the same as before.
Maybe I should get rid of those nasty characters before exporting to shape.
Thank you very much for your help.
Ervin.
Date: Fri, 18 Jul 2008 13:52:22 +0200
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] Postgis to ESRI shape file encoding problem
yes, you´re right; -W option only works with loader shp2pgsql.
The second option may be to define in the pgsql.conf file the following line:
client_encoding = sq-iso-8859-1 (i´not sure if Postgresql recognize the character encoding Latin1 for albanian as sq-iso-8859-1, but try with it or search the equivalent and write it in the pgsql.conf file). Afterwards, execute the dumper (pgsql2shp).
2008/7/18 Ervin Ramonllari <ervin.ramonllari at hotmail.com>:
I tried that,
it gives back an error. It doesn't recognize -W as an option or command.
Date: Fri, 18 Jul 2008 13:24:28 +0200
Try pgsql2shp option:
-W sq-iso-8859-1
In Albanian, there are 4 special characters.
Date: Fri, 18 Jul 2008 12:33:55 +0200
In wich language are data?
Hello everybody,
I'm trying to export some data from a Postgresql database encoded in UTF-8 into some ESRI shape files.
I'm using PostGIS Dumper (pgsql2shp).
the
export is done correctly, but some special characters could not be
exported properly. I guess it's a problem of encoding but I can't
figure out how to deal with it.
I googled around but couldn't find something useful.
Any help for solving my problem would be highly appreciated,
thanks in advance,
Ervin.
Explore the seven wonders of the world Learn more!
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Connect to the next generation of MSN Messenger Get it now!
_________________________________________________________________
Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy!
http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080718/50514796/attachment.html>
