[postgis-users] ndim vs. st_dimension and enforce_dims_coordinate constraint
Edward Bridges
postgis at eqbridges.com
Sun Jul 27 15:30:40 PDT 2008
thanks!
George Silva wrote:
> Yes!
> 2 for points, lines and polygons that dont have a Z value.
> George
> Edward Bridges escreveu:
>> Hmmm.
>> Ok so when I added the column, the paramters I passed where:
>> SELECT AddGeometryColumn('', 'point', 'coordinate', 600613, 'POINT', 0);
>> where 0 was the result of st_dimension, so should it be:
>> SELECT AddGeometryColumn('', 'point', 'coordinate', 600613, 'POINT', 2);
>> for a point?
>> Should it also be 2 for polygons -- given that these are the
>> dimensions of the same coordinate space?
>> Thanks!
>> Ed
>> pcreso at pcreso.com wrote:
>>> The number of dimensions in this case is teh number of coordinates,
>>> if your point has 2 (X & Y) then it is 2, not 0. If it is an XYZ
>>> point, then ndim = 3.
>>> ndim does not reere to points @ 0, lines @ 1 & polygons @ 2, but the
>>> dimensions of the coordinate space.
>>> Cheers,
>>> Brent Wood
>>> --- On Mon, 7/28/08, Edward Bridges <postgis at eqbridges.com> wrote:
>>>> From: Edward Bridges <postgis at eqbridges.com>
>>>> Subject: [postgis-users] ndim vs. st_dimension and
>>>> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
>>>> Date: Monday, July 28, 2008, 7:30 AM
>>>> Hello,
>>>> I have a table with a geometry column which the
>>>> AddGeometryColumn stored procedure has created a check constraint
>>>> like so:
>>>> Check constraints:
>>>> "enforce_dims_coordinate" CHECK
>>>> (ndims(coordinate) = 0)
>>>> So, this uses the internal function "ndims" to
>>>> check the dimensionality of the input coordinate.
>>>> However, I'm getting a discrepancy when inserting a
>>>> point into this column since ndims and st_dimensions are returning
>>>> conflicting (apparently) values:
>>>> rover=# select * from st_dimension(
>>>> ST_GeomFromText('POINT(1 1)'));
>>>> st_dimension
>>>> 0
>>>> (1 row)
>>>> rover=# select * from ndims( ST_GeomFromText('POINT(1
>>>> 1)'));
>>>> ndims
>>>> 2
>>>> (1 row)
>>>> It seems that the ndims function returns only 2, 3, or 4;
>>>> can someone please explain why the differing values and how to insert
>>>> data into a point-type geometry column (seems to work fine with
>>>> polygon) without crossing the check constraint?
>>>> Thanks,
>>>> Ed
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
