[postgis-users] insert .sql using script
searchelite searchelite at gmail.com
Mon Jul 28 20:20:16 PDT 2008
Thanks for the reply..
The reason why i want to do this is because i want to simulate real-time gps
data from gps collected table..
I have a gps record table, and i want to insert the record into the database
every ten seconds
Thanks
Obe, Regina     DND\MIS wrote:
> Yes.  Although it depends which environment you will be inserting from.
> psql may not be the best option.  If it is not an autogenerated sql
> file, I'm not sure why you would be doing this or maybe I just don't
> quite understand what you are saying.
View this message in context: http://www.nabble.com/insert-.sql-using-script-tp18644795p18704258.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
