[postgis-users] "Deutsches Hauptdreiecksnetz" missing in spatial_ref_sys
Frank Durstewitz
frank.durstewitz at emporis.com
Tue Jul 29 07:18:01 PDT 2008
Thanks Guido,
i found this record (and others which look similar), but it's not the
same and i need the exact definition.
The data i have to examine is claimed to be the exactest data available
for building positions in germany (top roof), and i have to verify this
very careful, because the whole dataset is very expensive.
Anyone other ideas?
TIA, Frank
Guido Lemoine am 29.07.2008 08:56:
> Frank,
> Look at EPSG=31469
> "PROJCS["DHDN / Gauss-Kruger zone
> 5",GEOGCS["DHDN",DATUM["Deutsches_Hauptdreiecksnetz",SPHEROID["Bessel
> 1841",6377397.155,299.1528128,AUTHORITY["EPSG","7004"]],AUTHORITY["EPSG","6314"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4314"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",15],PARAMETER["scale_factor",1],PARAMETER["false_easting",5500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","31469"]]"
> GL
> Frank Durstewitz wrote:
>> Hi together,
>> please, can someone convert the prj definition below into a insert
>> statement for use in spatial_ref_sys?
>> I got some data for evaluation, but since the datum is not in my
>> spatial_ref_sys, i'm stuck. And i'm not sure how to create the
>> necessary sql.
>> PROJCS["Transverse_Mercator",GEOGCS["Geographic Coordinate
>> System",DATUM["D_DEUTSCHES_HAUPTDREIECKSNETZ",SPHEROID["Bessel
>> 1841",6377397.155,299.1528131060786]],
>> PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],
>> PROJECTION["Transverse_Mercator"],PARAMETER["scale_factor",1],
>> PARAMETER["central_meridian",12],PARAMETER["latitude_of_origin",0],
>> PARAMETER["false_easting",4500000],
>> PARAMETER["false_northing",0],UNIT["Meter",1]]
>> TIA, Frank
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080729/686adc3e/attachment.bin>
