[postgis-users] How to tell if 2 geometries are spatially equal
Andy Anderson aanderson at amherst.edu
Mon Jun 2 22:58:32 PDT 2008
On Jun 2, 2008, at 4:29 PM, Martin Davis wrote:
> I use "topologically equal" because the OGC SFS specification uses
> the term "topology" extensively in their discussion of the meaning
> of the DE-9IM model, on which the semantics of ST_equals is based.
No doubt they do, because the spatial relationships that can be
determined by the DE-9IM are, generally speaking, topological in nature:
	Disjoint, Touches, Crosses, Within and Overlaps
These are the ones defined here:
	http://portal.opengeospatial.org/files/?artifact_id=829
Oddly, in this document they also mention "Equals" but they never
explicitly define it (though they claim to later in the document).
However, I did find a very complete description of DE-9IM here:
	http://mlblog.osdir.com/gis.postgis/2004-02/pdfHaVE9FZPMj.pdf
and they say that for "equals", the "Geometries must be identical:
– Same dimension
– Same geometry type
– Same number of vertices
– All x,y coordinates must be identical"
So this definition would seem to agree with me that LINESTRING(0 0, 10
10) and LINESTRING(0 0, 5 5, 10 10) are not topologically equal. The
best way to think of this is that the second is a *polyline*, and the
vertex (5, 5) is a boundary between two lines, and that changes the
DE-9IM.
As you point out, however, ST_equals('LINESTRING(0 0, 10
10)','LINESTRING(0 0, 5 5, 10 10)') returns true; perhaps this was by
design to distinguish it from 'LINESTRING(0 0, 10 10)'::geometry ~=
'LINESTRING(0 0, 5 5, 10 10)'::geometry .
If you can point to further discussion on this issue, I would be
interested.
> I don't like the term "spatially-equal", because I think "spatially"
> is too vague and overloaded.  How about "point-set equal"?  The idea
> is that  A = B iff every point of A is in B and every point of B is
> in A.
Personally, I don't have a problem with "spatially equal", it says to
me "they fill space in the same way", which in fact they do because a
point has no extent.
-- Andy
> Andy Anderson wrote:
>> I wouldn't call this example "topologically" equal; one has two
>> vertices and the other has three, and that's the only
>> characteristic that's relevant in topology (not even their
>> positions :-)
>> "Coincident" is probably a better term, though "spatially equal" is
>> probably just as good, and contrasts well with the term
>> "geometrically equal" that the manual uses to describe the ~=
>> operator.
>> -- Andy
>> On May 30, 2008, at 7:54 PM, Martin Davis wrote:
>>> Will ST_equals do what you want?  It reports whether two
>>> geometries are topologically equal.
>>> (So for example, ST_equals('LINESTRING(0 0, 10 10)','LINESTRING(0
>>> 0, 5 5, 10 10)') is true)
>>> Obe, Regina wrote:
>>>> I recall this having come up before.  I always thought that ~=
>>>> would
>>>> tell me if 2 geometries are spatially equal but it doesn't seem to.
>>>> The only way I can figure to determine spatial equality is if
>>>> ST_Within(A,B)  And  ST_Within(B,A)  (or ST_Difference(A,B) AND
>>>> ST_Difference(B,A) both return an empty geometry collection)
>>>> --So case in point
>>>> SELECT geom1 ~= geom2 as what, ST_Within(geom1, geom2) AND
>>>> ST_Within(geom2, geom1) As spatial_equal,
>>>>    ST_AsText(ST_Difference(geom1, geom2)) as diffgeom12,
>>>> ST_AsText(ST_Difference(geom2, geom1)) as diffgeom21 FROM (SELECT
>>>> 'LINESTRING(1 1, 1 2, 1 3)'::geometry As geom1,     'LINESTRING(1
>>>> 1, 1 3)'::geometry As geom2) As foo
>>>> Results:
>>>> what | spatial_equal |        diffgeom12        |        diffgeom21
>>>> f    | t             | GEOMETRYCOLLECTION EMPTY |
>>>> GEOMETRYCOLLECTION
>>>> EMPTY
>>>> Is there a function / operator that does that (also what does
>>>> geom1 =
>>>> geom2 compare - is it just bounding boxes or is that the
>>>> spatially equal
>>>> operator I am looking for?)
>>>> Thanks,
>>>> Regina
>>>> The substance of this message, including any attachments, may be
>>>> confidential, legally privileged and/or exempt from disclosure
>>>> pursuant to Massachusetts law. It is intended
>>>> solely for the addressee. If you received this in error, please
>>>> contact the sender and delete the material from any computer.
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> Martin Davis
>>> Senior Technical Architect
>>> Refractions Research, Inc.
>>> (250) 383-3022
> Martin Davis
> (250) 383-3022
