[postgis-users] create tables smarter
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Jun 4 13:51:20 PDT 2008
Kevin Neufeld wrote:
> Actually Lee, addgeometrycolumn does three things. Two, as you
> mentioned, and three, it adds constraints to your table so that all
> geometries in your column have the same srid and are of the same
> dimension and geometry type.
> The function Stephen mentioned does exist, but it's called
> probe_geometry_columns(). Unfortunately, it's not in the docs.
> postgis=# \df *probe*
> List of functions
> Schema | Name | Result data type | Argument data types
> public | probe_geometry_columns | text |
> (1 row)
Thank you for the correction. I shot that post off as I was running out
the door for a meeting, and didn't check the details.
I have always thought that the requirement for the geometry_columns
table was a little weird, but hey I wasn't asked when it was
implemented :) and I didn't do any of the work so I don't really have
anything to complain about. That said, it would be nice is this was
built and maintained totally transparently to the user and/or method of
creation/removal of a column. I guess this would require closer
integration with the pg_catalog and triggers on it or something like
that if that is even possible. I have not really looked into it, because
things just work most of the time.
-Steve
> This function was written quite some time ago, and in my opinion, only
> partially works. It adds missing entries to the geometry_columns table
> by scanning the system tables for the three above mentioned constraints.
> In other words, if the three constraints don't live on your new
> geometry table, it won't add an entry to the geometry_columns table.
> Further, this function does not remove obsolete entries from the
> I wrote my own function that truncates and repopulates the
> geometry_columns table by scanning the system tables for columns of type
> 'geometry', rather than looking for existing constraints. It tries to
> add the constraints to the table the geometry is in (sending you a
> warning if it failed), and inserts a row in the geometry_column table. I
> suppose one of these days, I should add it to the postgis source.
> Cheers,
> Kevin
> Lee Hachadoorian wrote:
>> Andreas,
>> AddGeometryColumn does two things: it adds a column of type geometry,
>> and it adds a row to table geometry_columns. If I understand what it
>> is you want to do, you can do the SELECT and then add the row to
>> geometry_columns with an INSERT statement:
>> INSERT INTO public.geometry_columns
>> VALUES
>> ('',<schema_name>,<table_name>,<column_name>,<dimension>,<srid>,<type>);
>> where the arguments use the same values you would use for the
>> AddGeometryColumn function.
>> Stephen, I don't see anything about a probegeometrycolumns( ) function
>> in the PostGIS docs. Can you point me in the right direction?
>> Thanks,
>> Lee Hachadoorian
>> PhD Student, Geography
>> Program in Earth & Environmental Sciences
>> CUNY Graduate Center
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
