[postgis-users] GIST index speed
Kevin Neufeld
kneufeld at refractions.net
Wed Jun 4 17:19:52 PDT 2008
Are you using within() or ST_Within()? The latter automatically uses the
gist index, the former does not.
-- Kevin
Peck, Brian wrote:
> Hey all,
> I currently am working on a PostGIS database (Postgres 8.3) and the
> requests are going slower than expected.
> The table I’m querying off of has ~42000 entries in it, and the
> geometry field I’m using has a gist index on it. The query however is
> taking ~6 seconds to return me the entries.
> I am making the query
> SELECT * FROM asdfs_track_point where
> within(the_geom,GeometryFromText('POLYGON((-180.0 -90.0,-180.0
> 90.0,180.0 90.0,180.0 -90.0,-180.0 -90.0))',4326));
> This is a test case and so I am doing the entire world to find out how
> long things should take, but I’m told that with only 42000 rows in the
> table it should be faster than 6 seconds.
> Anyone have any idea why it might be going slow, or a way to speed up
> the query?
> Thanks,
> - Brian Peck
> - 858-795-1398
> - Software Engineer
> - Lockheed Martin
> postgis-users mailing list
