[postgis-users] Creating a Flow Diagram
Sufficool, Stanley
ssufficool at rov.sbcounty.gov
Thu Jun 5 11:15:59 PDT 2008
OK, I'm trying to come up with a solid solution to all this since it
roughly applies to some things I'm doing with attached objects and
location tracking.
This rule is resulting in infinite recursion when there is no reason for
the rule to even execute.
Am I understanding the rules system wrong or should this be a trigger
function?
create or replace rule entity_update AS ON update TO entity
WHERE NOT (st_AsText(OLD.the_geom) ~= st_AsText(NEW.the_geom)) -- Only
if geometry was modifed (I'm sure there is a more appropriate operator
here)
DO UPDATE entity
SET the_geom = st_translate(
-- Center the child on parent geometry
st_translate(
the_geom,
st_x(st_centroid(NEW.the_geom)) -
st_x(st_centroid(the_geom)),
st_y(st_centroid(NEW.the_geom)) -
st_y(st_centroid(the_geom)),
st_z(st_centroid(NEW.the_geom)) -
st_z(st_centroid(the_geom))
--Translate to relative position of parent
( st_xmax(NEW.the_geom) - st_xmin(NEW.the_geom) ) *
ratio_x,
( st_ymax(NEW.the_geom) - st_ymin(NEW.the_geom) ) *
ratio_y,
( st_zmax(NEW.the_geom) - st_zmin(NEW.the_geom) ) *
ratio_z
WHERE parent_entity_id = NEW.entity_id --Update all children of
the modified parent record
-- NOW LETS touch the parent
update entity SET the_geom = st_translate(the_geom, 0, 0) where
entity_id = (SELECT MIN(entity_id) FROM entity)
ERROR: infinite recursion detected in rules for relation "entity"
********** Error **********
SQL state: 42P17
Type: application/octet-stream
Desc: diagram2.sql
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080605/a707ab69/attachment.obj>
