[postgis-users] GIST index speed
Steve Kondik
shade at chemlab.org
Fri Jun 6 08:48:40 PDT 2008
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Mark Cave-Ayland wrote:
>> Hash: SHA1
>> I'm seeing this same kind of slowness. I am in the process of migrating
>> an application from Oracle to Postgres. One query that seems to take
>> longer than it should is a very simple point-in-bbox query which takes 3
>> seconds. There are 32000 rows in the table, and the query is as simple
>> as it can be:
>> select count(*) from geography where type='Z' and centroid && (select
>> geometry from geography where id=69495);
>> The second geography is the USA, so this query gets all zipcodes inside
>> the bbox, using precalculated centroids. The query plan looks fine as
>> well:
>> Aggregate (cost=16.56..16.57 rows=1 width=0) (actual
>> time=2407.123..2407.125 rows=1 loops=1)
>> InitPlan
>> -> Index Scan using geography_pkey on geography (cost=0.00..8.28
>> rows=1 width=4528) (actual time=0.027..0.030 rows=1 loops=1)
>> Index Cond: (id = 69495)
>> -> Index Scan using idx_geography_centroid_z on geography
>> (cost=0.00..8.28 rows=1 width=0) (actual time=1.417..2355.049 rows=29687
>> loops=1)
>> Index Cond: (centroid && $0)
>> Filter: (centroid && $0)
>> Total runtime: 2407.194 ms
>> (8 rows)
>> Any thoughts? This query takes 200ms on Oracle. It seems like
>> something is wrong for it to take 3 seconds on PostGIS. It's faster for
>> smaller geometries (like a state), but I don't understand why since its
>> just point-inside-bbox.
> Hi Steve,
> Well from the above you can see fairly easily that the time is
> disappearing into the second index scan. The above output doesn't look
> quite right somehow (it's missing at least one node indicator) - can you
> try cutting and pasting the exact output from EXPLAIN into an email
> again? Also we'll need the output of "\d geography" from within psql.
> ATB,
> Mark.
Sure thing. It's taking quite a bit longer now because we're doing some
bulk loading. When nothing else is running, the query takes about 4
seconds.
health_central_22=> explain analyze select count(*) from geography where
type='Z' and centroid && (select geometry from geography where id=69495);
QUERY PLAN
time=16534.739..16534.741 rows=1 loops=1)
InitPlan
rows=1 width=4528) (actual time=0.076..0.080 rows=1 loops=1)
(cost=0.00..8.28 rows=1 width=0) (actual time=25.453..16192.427
rows=29687 loops=1)
Total runtime: 16534.809 ms
(8 rows)
health_central_22=> \d geography
Table "public.geography"
Column | Type | Modifiers
type | character(1) | not null
id | bigint | not null
centroid | geometry |
geometry | geometry |
name | character varying(32) | not null
population | bigint |
abbreviation | character varying(2) |
po_name | character varying(100) |
id_geo_state | bigint |
Indexes:
"geography_pkey" PRIMARY KEY, btree (id)
"idx_geography_2" btree (name)
"idx_geography_3" btree (abbreviation)
"idx_geography_4" btree (id_geo_state)
"idx_geography_centroid" gist (centroid)
"idx_geography_centroid_c" gist (centroid) WHERE type = 'C'::bpchar
"idx_geography_centroid_s" gist (centroid) WHERE type = 'S'::bpchar
"idx_geography_centroid_z" gist (centroid) WHERE type = 'Z'::bpchar
"idx_geography_geometry" gist (geometry) CLUSTER
"idx_geography_geometry_c" gist (geometry) WHERE type = 'C'::bpchar
"idx_geography_geometry_r" gist (geometry) WHERE type = 'R'::bpchar
"idx_geography_geometry_s" gist (geometry) WHERE type = 'S'::bpchar
"idx_geography_geometry_z" gist (geometry) WHERE type = 'Z'::bpchar
Foreign-key constraints:
"fk_geography_1" FOREIGN KEY (id_geo_state) REFERENCES geography(id)
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFISVxYMrBfzfMVwMcRAuGqAJwKuzfibrWuPb+d0Udxs1H3gt2gswCfVdTa
AKVUEcS0pBVETvaeBkat+hQ=
=DBKC
-----END PGP SIGNATURE-----
