[postgis-users] Meteorological visualization
Tyler Erickson
tyler.erickson at mtu.edu
Fri Jun 6 14:40:33 PDT 2008
Romel,
You certainly could store your met data in postgis. A simple table
structure would likely have the following three tables:
locations - information on where the sites are located
parameters - information on the meteorological parameters (i.e. temp,
humidity, etc)
observations - information on what was measured and when it was
measured. Records would be linked by foreign keys to the location and
parameter table.
I
f you want an example of how to create something similar for PostGIS, I
have something similar that we use for storing water quality
measurements. Let me know if you want a copy of the table creation script.
If you are interested in visualizing the data as a time series you could
query PostGIS and generate graphics on the fly using one of the following:
http://simile.mit.edu/timeplot/
http://code.google.com/apis/chart/
Hope that helps,
Tyler
Romel Vazquez Rodriguez wrote:
> Hello people, I have a geometry map in postgis and i also have group of meteorlogical variables that would like to visualize over the map. That variables are asociated to one meteorological station in the map. I need to know if any one have done something like that. the variable are temperature, humedity, wind speed, cloudiness, etc.
> If any one have done something similar, in postgis o other format, please let me know.
> Thanks Romel
> ________________________________
> Servicio de Correos de la Universidad Central "Marta Abreu" de Las Villas. http://www.uclv.edu.cu
> -VI Conferencia Internacional de Ciencias Empresariales, del 16 al 18 de octubre de 2008, Cayo Santa María, Cuba. http://economia-publica.uab.es/VIcubaCICE.doc
> -V Conferencia Científica Internacional de Ingeniería Mecánica, COMEC 2008, del 4 al 6 de noviembre de 2008, UCLV, Cuba. http://eventos.fim.uclv.edu.cu/comec
> postgis-users mailing list
Tyler A. Erickson, Ph.D.
Research Scientist
Michigan Tech Research Institute
3600 Green Court, Suite 100
Ann Arbor, MI 48105
W 83.6889°, N 42.3021° (WGS84)
(734) 913-6846
www.mtri.org
www.michiganview.org
